Considering '19 CPO RDX, 21k miles, but the front brakes were replaced at 4.6k miles
Hi All,
I'm thinking of buying a 2019 CPO RDX with 21k miles. It has a clean Carfax with the maintenance done at 4600, 8400, 13,800, 19,500, and 21,400. But at the 4600 service, the dealer replaced the front brakes. How do brakes only last 4600 miles? What could cause this? Could the brakes have been defective? Also, according to Consumer Reports, brakes are a trouble spot with the 3rd Gen. Is this a known issue? Any info would be appreciated! Thank you!
Hi All,
Squeaky brakes covered under warranty. Its a known problem and easy fix. You shouldn't hear anything anymore.
leomio2.0 (09-20-2021)
OG
On the CPO checklist part of the requirement is certain mm on rotors n pads
it should list on the dealers site what the measurements are
on ours part of the process AFTER purchase is to get n emil copy of that form and carfax etc
I don't think you need to be worried about this early brake parts change in the car you are interested in.
I had mine replaced with only like 500 miles. The brakes worked fine, they just squealed the first few stops when it was cold. I would not expect any shorter than usual brake life as a result of this. A significant number of 2019 RDX's had this issue and it was a quick and painless fix.
JB in AZ (09-20-2021)
Several RDX Gen 3 owners were having squealing brakes. Acura issued a TSB (and a couple of updates) that included replacing the pads all around and the front rotors. I had a slight squeal, but not enough to be a bother. I casually mentioned it to the dealer when I had it in for an oil change, and they replaced the pads all around and front rotors.
2020 RDX White/Espresso
I’m more curious about the services at 19k and 21k. Why two services in 2k miles?
it's like a $.02 part.
furthermore; brake pads are a wear component...meaning; even tho they were recently replaced (because of common noise) they can still wear out by 21k.
I wouldnt have any concerns buying this RDX....
what''s the link for it, so i can buy it?
it's normal practice to replace the Schrader valve, even when just checking pressure.
justnspace (09-21-2021)
OG
could have been something warped, an ocd owner. Just be happy it was owned by someone who took it in lol
we got our 2019 Aspec awd cpo w/29,900 a month ago and i logged into acura for the service records
all routine maint, a parking sensor was faulty and fuel pump recall… its been awesome
I recently started watching and following this automotive tech on youtube.
at 2:30, you can watch him replace the valves and he quips "I'll change out these valves like I always do"
which is the 2nd video that I've seen him change out the schrader valves in the A/C service ports.
The expansion valve/orifice is not a schrader valve, it's a part inside the system. It meters the flow of refrigerant and atomizes it as it flows into into the evaporator. If it clogs, the system won't cool much, if at all. Replacement requires evacuating the system and opening the line to the evaporator, replacing the part, then evacuating & recharging the system. It's a cheap part but lots of labor to replace it. Not a major job but more complicated than replacing the schrader valves. They usually don't need attention unless something happened in the system that releases something that clogs it...might have been in there since new.
justnspace (09-25-2021)
