Car hangs on first gear??
Old Nov 29, 2018 | 08:57 PM
chkelly's Avatar
Every couple of days i notice the RDX hangs on a low gear, i believe the first gear, while in regular drive. If im going 20-30 MPH my foot is static on the pedal, giving it some gas but not progressively pushing harder, the RPMs will continue to go up and the engine will get louder but it wont shift until i give it more gas and push down harder on the pedal. This doesnt seem normal...It seems to go away if i put it in park then drive again. Anyone run into this?
Old Nov 29, 2018 | 09:16 PM
Burger Steak & Eggs's Avatar
I've noticed this when the engine is cold.
Old Nov 29, 2018 | 10:39 PM
Yotrek's Avatar
Sounds like your in manual mode, if you accidentally press the D/S button twice you’re in the manual mode...
Old Nov 30, 2018 | 08:50 AM
chkelly's Avatar
Nope, its in D.
Old Nov 30, 2018 | 08:51 AM
chkelly's Avatar
Cold, as in literally cold outside? or just he first time you drive it after a day or two?
Old Nov 30, 2018 | 09:13 AM
rdxny's Avatar
Happened twice to me so far...
Old Nov 30, 2018 | 12:23 PM
Njbrandon's Avatar
I've noticed this too but only when the car hasn't fully warmed up.
Old Nov 30, 2018 | 12:33 PM
Dereileak's Avatar
I don’t know what exact fluid Acura is using in this transmission but I think whatever fluid they are using is too thick when the weather is cold, if you live in California it’s no big deal, but I live in Minnesota and it can get to -30f in the winter before windchill, my car shifts rough just being in the 20-30s when first driving until it warms up and we still have 30-50 more degrees to drop in temp, I can’t wait to see how this car shifts when it’s transmission fluid is -30 degrees f 😂
Old Nov 30, 2018 | 12:59 PM
zroger73's Avatar
The 8-speed automatic transmission in my brother's 2018 Chevrolet Colorado (and others) "hangs" in second gear for what seems like an eternity when the engine is cold.
If the transmission was actually "hanging" and not upshifting when commanded by the TCM, you'd get a warning light/message. Most likely, the transmission is "hanging" because it's being told to by the TCM. It could be a software bug that becomes apparent under some conditions or it could be an intentional warm-up strategy (assume it's only doing it when cold).
You're not in manual mode until you press the D/S button twice THEN pull a paddle shifter. Until you do the latter, shifts are still fully automatic.
Old Nov 30, 2018 | 05:29 PM
RDXRSXTL's Avatar
Relax
Every vehicle with an automatic transmission I have ever driven in my nearly 60 years of driving does this to one degree or another. I think it is more noticeable as the number of gears increases - & I'll bet most of us have not previously driven a 10 speed (except bicycles).
Old Nov 30, 2018 | 08:16 PM
The latter. It might be an attempt to heat up the catalysts more quickly so they can do their job.
Old Nov 30, 2018 | 08:46 PM
Wander's Avatar
Not true. It won't enter "manual mode" unless you yank a paddle shifter, in either D or S.
In D, it will eventually get bored and go back to full auto shifting after a paddle yank, unless you keep yanking.
In S, one yank is enough to keep it in manual sequential mode.
If you refrain from yanking, S just alters the shift points and keeps the revs up, for Sportiness.
Having said all this, it is possible to yank by accident, and the consequences will be more apparent in S mode.
Old Dec 5, 2018 | 12:42 AM
Shampoch's Avatar
It has happened to me after accidentally hitting the paddle in D mode.
mohammad najaar
Integra
Jan 15, 2017 10:18 PM
Austin519
Sep 9, 2002 12:15 AM
