All door unlock.
Old Nov 12, 2018 | 07:19 PM
tabs31's Avatar
All door unlock.
I can't seem to be able to locate where the setting is to do the following: all door unlock as I approach to vehicle as it senses the keyfob being nearby. Could someone please assist?
​​​​​​Thanks for your help!
Old Nov 12, 2018 | 07:33 PM
billyt1963's Avatar
I did a quick look through the manual and did not see anything about auto unlock. There is the auto lock feature on walk away, but that is all I found.
Billy
Old Nov 12, 2018 | 07:42 PM
RDXRSXTL's Avatar
Page 348 of owner manual
Not easy to find in the book, but found in 5 seconds with a search of the pdf version for "all doors".
Old Nov 12, 2018 | 08:32 PM
tabs31's Avatar
Unfortunately that doesn't have to do with the doors unlocking by themselves when the car senses the keyfob nearby.
Old Nov 13, 2018 | 10:25 AM
Mustachio's Avatar
All settings pertaining to the door lock/unlock are in the infotainment settings. Can't remember the exact location but it's not hidden. I wasn't aware the RDX had a proximity UNlock feature. I wouldn't want the car to unlock as I approach in case someone was aware of that feature and wanted to jump in before I get inside. If you want to unlock all the doors easily, just tap the rear door handle when you approach.
Old Nov 13, 2018 | 01:03 PM
jonarogers's Avatar
The car doors will not unlock simply by location. You have to touch the door handle. They WILL lock if you turn the car off and walk away (per a setting you have to enable).
LIPPSTUH
Jun 9, 2008 01:10 PM
jwk06rl
Aug 26, 2006 02:06 PM
JaTe
24
Aug 21, 2003 02:32 PM
