Adding rear camera washer to A-Spec
Old 03-03-2019, 12:55 AM
Dereileak's Avatar
So I was wondering if anyone has a pic of where the camera washer is and what it looks like when it’s out. I really want to add this to my aspec, from what I can tell it activates with the rear window washer, wondering if it would be something I could order parts for the add or if it changes any major panels where I couldn’t do that.
Old 03-03-2019, 12:58 AM
RDX10's Avatar
The rear camera washer is implemented into the main body of the camera housing. I.e it is a little round cover that comes out from beside the camera and sprays it. I think it's ingenious. As per how easy it would be to DIY. I personally think it would be very doable. Simply needs a tube from the rear washer line and to be wired to the rear wiper. The only issue I forsee is how to make it so it doesn't come out when you're simply turning on the rear wiper without water.
Old 03-03-2019, 12:59 AM
Dereileak's Avatar
Originally Posted by RDX10
The rear camera washer is implemented into the main body of the C
well that sucks ha ha
Old 03-03-2019, 01:02 AM
RDX10's Avatar
Lol you caught me before I had a chance to fix my accidental post 😂😂
Old 03-03-2019, 01:03 AM
Dereileak's Avatar
Email notifications 😁 do you have a pic of it I am just curious what it looks like
Old 03-03-2019, 01:06 AM
RDX10's Avatar
I tried screenshotting but my stupid android won't let me. Here is a link, if you scroll down a few pics you can see it.
https://www.google.com/amp/s/thecanadiantechie.com/2019/02/11/2019-acura-rdx-review/amp/
Old 03-03-2019, 01:09 AM
Dereileak's Avatar
thanks! oh my this is totally doable to add if I can figure out the part
Old 03-03-2019, 01:11 AM
RDX10's Avatar
You're welcome!
It is definitely definitely doable! I'd say with very minimal work too seeing as how it comes as one unit!
Is it available on any trims in the U.S?
Dereileak's Avatar
You're welcome!
comes with the advanced trim, the problem is figuring out the part. @Wander any idea on this?
Old 03-03-2019, 01:21 AM
RDX10's Avatar
He'll probably have some ideas. He's kinda very brilliant!
Old 03-03-2019, 01:24 AM
Dereileak's Avatar
Idk if this would be what I need, I’m not looking to replace the whole camera, not sure if it would be part of the camera assembly or a part that attaches to it, really need to see a diagram
Old 03-03-2019, 01:43 AM
Dereileak's Avatar
Oh I found the nozzle assembly !!! Wonder what other parts are needed, I believe it just taps into the rear window washer, I see a bunch of other parts that are available to buy
https://www.oemacuraparts.com/v-2019...dshield-washer
If I can figure it all out I will be adding this to my A-Spec
Old 03-03-2019, 11:54 PM
Dereileak's Avatar
I paid for 30 days of tech info, more to come on this subject
Old 03-04-2019, 01:25 AM
Wander's Avatar
Camera assembly is a different part number for Advance vs other trims ( including A-spec ). The only obvious reason for this is to accommodate the washer nozzle. This might be a deal breaker, unfortunately.
Otherwise, just some plumbing. But I'm not coming up with good parts diagrams.
But I'm really enjoying these dirty pics of an RDX's rear end...
Dereileak (03-04-2019)
Old 03-04-2019, 01:51 AM
Dereileak's Avatar
I was able to find all the required parts, for the nozzle hoses and everything its about $50, but to get the nozzle built into the camera assembly I would have to order the advanced camera which is $130 discounted really sucks when its literally the plastic piece the camera mounts to that I need
total of $180 before shipping for everything I would need, not sure if this is really worth it, consider I have heard the Advanced camera quality is worse, and there is no guarantee that camera would work with the A-spec
done need part 16 as that comes with the Aspec, just part 10 and then everything else down that line there
MSRP from dealer saying 254 but from https://www.oemacuraparts.com I am at $180 total
literally if I could buy the little plastic frame that goes around the camera, would be a cheap part, then this would be a $60 swap, but not the case :/
Old 03-04-2019, 08:48 AM
samiam_68's Avatar
Anyone here well versed with CAD and has a 3-D printer?
Old 06-25-2019, 12:49 PM
Mustachio's Avatar
Yes. I am planning to do this exact project or at least 3D print a "visor" for the camera...someday. Right now it's summer so I have very little need for it. Once I have a better idea of the required design, I can whip this up in a couple days.
Old 09-17-2019, 10:39 PM
garunas's Avatar
Any successful projects?
Old 12-23-2019, 10:08 AM
Dereileak's Avatar
did you ever try this?
Old 12-29-2019, 08:34 PM
Mustachio's Avatar
No, I still haven't. I've been working on interior projects (rerouting the media USB port, upgrading the sound system).
Old 02-11-2024, 04:40 PM
BeniB's Avatar
I know this thread has been quiet for a long time, but I wanted to post that I finally added back-up camera washer to my 2020 A-spec. The process was not as easy as I hoped for, but it's certainly doable. Here we go:
1- I bought a used advance backup camera assembly from eBay for about $60 USD.
2- I removed my 2020 A-spec camera assembly and encountered the first problem: A-spec camera has male connector while advance camera has female connector.
3- For a while I was searching for a 6-pin male-female adapter but did not have any luck, and even if I had found one I wasn't sure it would work properly. These two cameras are entirely different since advance camera is part of the 360 view system and I wasn't sure whether the A-spec head unit would recognize it. Anyways, I decided to remove the cameras from their respective housings and install the A-spec camera on the Advance camera housing. The good news is the advance camera housing fits perfectly in the tailgate and no modification is required there.
4- Again, since these two cameras are different their housing cutout to accommodate camera as well as screw hole locations on the housing are different. So, I had to manually cut the advance camera housing such that the A-spec camera sits flush with housing.
5- Once the cutout is done, then you need to carefully drill holes in the housing so the A-spec camera can be properly secured.
6- Final part is piping which is the easiest part: Just need to add a T-junction with a hose (both bought from Amazon) to the rear washer fluid which is on the right tailgate hing.
Left: advance rear camera assembly Right: A-spec rear camera assembly
A-spec camera overlaid on the advance camera housing. You can see that you will need to add few cut outs to make room for the camera pin. Also, need to drill two holes (top right and bottom left) to secure the camera.
Washer in action
The following 6 users liked this post by BeniB:
amcobra (02-11-2024), NBPDC505 (02-12-2024), RDX10 (02-12-2024), samiam_68 (02-12-2024), sonyfever (02-11-2024), thoiboi (02-12-2024) and 1 others liked this post. (Show less...)
Old 02-11-2024, 11:17 PM
sonyfever's Avatar
Excellent, thanks for sharing. Looks like if one buys the 22+ A-spec camera (39530-TJB-A11), it should be a drop-in replacement.
Old 02-12-2024, 01:02 PM
BeniB's Avatar
Your welcome!
​​​​​​​Keep in mind that A-spec's wire harness is female. So, your camera must have a male pin out. Do you have a picture of a 2022+ rear camera assembly? I didn't find a picture online for the part number you mentioned.
Old 02-12-2024, 04:04 PM
RDX10's Avatar
Washer in action
This is amazing!! Thank you so much for this! Living in Canada, during the winter this is a huge pain in the ass. Love this!
Old 02-12-2024, 08:31 PM
BeniB's Avatar
Thanks! It's a fun diy project and the result certainly is worth the effort.
Old 02-12-2024, 09:22 PM
sonyfever's Avatar
Your welcome!
https://www.ebay.com/itm/25610775469...cAAOSwG59kh1SP
BeniB (02-13-2024)
Old 02-13-2024, 06:30 AM
BeniB's Avatar
This would have been a much easier part to use!
Old 02-13-2024, 09:46 AM
Twism86's Avatar
I keep seeing so many features the A-Spec Advance has over the standard A-Spec that im wishing I dished out the extra coin for one
The following 2 users liked this post by Twism86:
quikj (02-22-2024), sonyfever (02-13-2024)
Old 02-13-2024, 05:51 PM
RDX10's Avatar
So they changed over the camera from the advanced to the Aspec design for 2022+ models?
Old 02-19-2024, 11:12 PM
sonyfever's Avatar
Need tip on the installation. I think one can remove the camera module from the small access panel on the tailgate. For the washer fluid pipe, do you remove the plastic lining on the right side of the rear window, and fish the tube over to the access panel area?
Old 02-20-2024, 05:10 AM
BeniB's Avatar
You need to take off three trim pieces for this. If you already don't have a set of plastic prying tools, buy yourself a set to make this an easier process.
1- Remove left and right tailgate hinge covers. Each of them is secured by a plastic pin. Remove the pins first, and then pry out the trims.
2- The middle tailgate trim: once you have removed the tailgate covers, you'll see that the middle trim has also two pins on either side. Take them out first and then pry out the trim. You have now full access to the rear camera.
The small plastic trim in the tailgate only gives you access to the tailgate lock mechanism and it's not related to camera housing. You don't need to remove it.
sonyfever (02-20-2024)
Old 02-20-2024, 09:04 AM
8th Gear
Mo3MoE's Avatar
Just purchased a 2024 A-Spec Model. The Advance I Believe Has HUD, Heated Steering Wheel, Rain Sensor Wipers, Folding Side Mirrors, Different Wheels & Comes With Remote Start. Its Definitely Nice To Have. The wheels that it comes with I didn't like & also 4k more for it. In my opinion, was not worth it. I'm happy with My A-Spec.
Old 02-21-2024, 11:11 AM
Texasrdx21's Avatar
Originally Posted by Mo3MoE
Just purchased a 2024 A-Spec Model. The Advance I Believe Has HUD, Heated Steering Wheel, Rain Sensor Wipers, Folding Side Mirrors, Different Wheels & Comes With Remote Start. It's Definitely Nice To Have. The wheels that it comes with I didn't like & also 4k more for it. In my opinion, was not worth it. I'm happy with My A-Spec.
Agree - Less to go wrong long term. I too prefer the standard Aspec wheel over the Aspec Advanced wheel. Though, some of the options I would like the HUD, 360 camera and thigh support adj seat - can live without the adj dampers, folding mirrors, Heated Steering Wheel, Rain Sensor Wipers and remote start. However, $4k is a big number to use elsewhere - IMO.
Old 02-24-2024, 07:37 PM
sonyfever's Avatar
Thanks a lot for your immensely helpful tips. One more question, in the factory diagram there is a $30 filter inline. I wonder if you added any filter, or just run the pipe straight to the sprayer?
Old 02-25-2024, 06:06 PM
BeniB's Avatar
I didn't add any filter. I simply removed the inline connector and replaced it with a generic T-junction from Amazon.
sonyfever (02-25-2024)
Old 02-26-2024, 12:24 AM
sonyfever's Avatar
Thanks. I installed the MMC A-spec camera module, and will try adding photos after I clean up my installation. Here are my early observations:
  • The MMC module is a direct fit. Just need to add piping.
  • Video quality:
    • The resolution is about the same, if not worse on the corners.
    • Has better dynamic range and lower noise. Low-light view is remarkably clean, and a huge improvement over 19-21 unit.
    • Color is slightly richer, but not as dramatic as the low-light improvement.
  • The field-of-view is slightly wider than 19-21, and the camera position is slightly offset to the driver side.
  • As a result, the guidelines are off. The actual distance of the solid/dashed markers are further away, and the left-right lines are also different in ways that I have not figured out yet.
Old 02-26-2024, 03:00 PM
RDX10's Avatar
  • Video quality:
Oof I was very onboard with this until your last bullet point. That would drive me absolutely bonkers.
Old 02-27-2024, 09:10 AM
BeniB's Avatar
You can easily swap your 19-21 A-spec camera with 22+ A-spec camera (19-21 camera attached to 22+ camera housing). It's only 4 screws. This way, you won't have any calibration issue.
The following 2 users liked this post by BeniB:
RDX10 (02-28-2024), sonyfever (02-29-2024)
Old 02-28-2024, 02:29 AM
RDX10's Avatar
Thanks man this is definitely something I could see myself doing and I love that you went for it! In Canada during the winter the camera is nasty 90% of the time and by the time I realize I'm already heading out and don't want to leave the warm car to clean it off.
Old 02-29-2024, 10:20 PM
sonyfever's Avatar
Yes that would be a good option. I thought about this, but the improved video quality is good enough that I decided to stick with 22+ camera for now.
Quick Reply: Adding rear camera washer to A-Spec
