Engine Oil Info
Old 09-08-2013, 12:52 PM
sbkim's Avatar
Engine Oil Info
Manual recommends 0W-20 but doesn't seem to require synthetic oil. Does the car come with regular oil but you can use synthetic?
Old 09-10-2013, 12:31 AM
SkylineUSA's Avatar
That's correct.
Old 09-10-2013, 07:24 AM
Received 16,260 Likes on 11,971 Posts
Most synthetics are BLENDS of regular oil, anyway.
and then a 0w-20 is supposed to be a synthetic from Honda.
so, it really doesnt matter what oil you put in.
as long as you change the oil and the oil filter regularly according to the MID.
depending on location I would stick with a 5w-30/20 or a 0w-20
Old 09-10-2013, 09:03 AM
sbkim's Avatar
Thank you all. Any specific brands you guys recommend? I was going to get a quart of Mobile One to keep around in case I am running a little low.
Old 09-10-2013, 09:08 AM
^doesnt matter the brand. mobil 1 is good.
as long as you change the oil and oil filter regularly.
Old 09-10-2013, 11:27 PM
SkylineUSA's Avatar
Mobil 1 is a good economical choice for a full synthetic oil (no dino).
Old 09-11-2013, 01:56 PM
sbkim's Avatar
Given that the car comes with dino oil from factory, what name brand is in compliance with factory oil? I presume most big brands would be... Or should I just bite the bullet and get it from the dealer?
Old 09-11-2013, 02:00 PM
^if most synthetics are blends of dino oil, and a 0w-20 is classified as a synthetic oil, you wont go wrong with any brand named oil.
depending on climate, i would choose a 5w-30 or a 0w-20. at engine temp, those two are basically the same weight.
Old 09-11-2013, 02:01 PM
only their 0w-40 is a full synthetic.
anything else that comes from mobil 1 is a blend.
Old 09-13-2013, 02:08 PM
SkylineUSA's Avatar
That is incorrect. All Mobil 1 oils are full synthetic.
http://www.mobiloil.com/USA-English/...s/Mobil_1.aspx
The world's leading synthetic motor oil brand, Mobil 1™ is an advanced full synthetic motor oil family that provides performance beyond conventional motor oils.
Specifically, I've been using their 5w30 in my Subaru Impreza WRX for 12 years, and it is a full synthetic:
http://www.mobiloil.com/USA-English/...l_1_5W-30.aspx
Mobil 1™ 5W-30 is an advanced full synthetic motor oil designed to keep your engine running like new by providing exceptional wear protection, cleaning power and overall performance. It meets the demanding ILSAC GF-5 performance standards, and is dexos1™ approved by General Motors.
I've just purchased a case of 0w20 for my 2014 MDX, and it too is a full synthetic:
http://www.mobiloil.com/USA-English/...l_1_0W-20.aspx
Mobil 1™ 0W-20 Advanced Fuel Economy synthetic oil is engineered to help improve fuel economy in vehicles where SAE 0W-20 or 5W-20 motor oil is recommended. An advanced full synthetic motor oil, it is designed to help deliver outstanding engine protection and enhanced fuel economy. It meets or exceeds ILSAC GF-5 requirements.
sbkim (09-13-2013)
Old 09-24-2013, 08:58 AM
scout27's Avatar
Just did my first oil change. Mobile 1 0W20 all the way. Oh, by the way, the oil filter positioning is one of the worst I've ever had from a Honda product. The end of the filter is 1" or less from a suspension or frame member. Hard to fit a end cap wrench between the two and lots of oil runs directly down on the frame member. Lots of clean up required!
However, this is the only negative I've had with my new '14 MDX. Great vehicle.
Old 09-25-2013, 04:16 PM
6th Gear
FB-MDX's Avatar
Did you jack up the front wheel to get to the filter?
Old 09-29-2013, 06:03 AM
scout27's Avatar
No,
I just ran the vehicle up run-up ramps to get underneath.
Old 09-29-2013, 05:11 PM
6th Gear
FB-MDX's Avatar
No,
Thanks...good to know i won't need to jack it to get to the filter.
oo7spy
06-19-2023 12:48 AM
01CLOwner
10-09-2015 01:07 PM
pizokk1
09-17-2015 09:29 AM
datadr
09-12-2015 09:12 PM
Quick Reply: Engine Oil Info
