Beak removal help - AcuraZine - Acura Enthusiast Community
Notices
Beak removal help
Old 02-08-2019, 04:57 PM
Registered Member
Beak removal help
I am trying to make a DIY for deleting the beak. Now before anyone says anything, I have tried contacting that guy that does it for the TLX. He replied twice and that was it. Never heard from him again. I understand he is probably busy but I want to attempt it myself.
I ordered some of the parts I need. The problem is that, the grill I ordered from eBay said is for a 2017-2018 MDX but it doesn’t seem like it. It’s small and it doesn’t cover up the old grill.
Yes, I know there are other options like, painting the beak. Honestly I am not into it. But if I can get a DIY going for everyone else, that would be awesome.
Can someone with a 2017+ MDX measure their grill? I have pictures to show where I would need measurements. You can also see in the pictures where the new grill won’t cover the old.
AdiosPantalones is offline
Old 02-08-2019, 05:05 PM
Steve
BreezyTL's Avatar
The grill is for a 17-18 and you have a 15-16. Of course it won't fit, they are completely different front ends.
BreezyTL is offline
Old 02-08-2019, 05:17 PM
Registered Member
ok so how is that hat other guys making them fit or even doing it
Old 02-08-2019, 05:24 PM
Steve
BreezyTL's Avatar
You would have to take measurements. I am sure the TLX grille is not as wide as yours to start. Cut, trim, glue, screw it all together. If you can't figure out what grill to use, I wouldn't try this at all. You will just end up with a jacked up front end that looks like crap.
Not trying to discredit your abilities but from an initial read, you don't know what you're doing. I'd leave it to the professionals!
BreezyTL is offline
Old 02-08-2019, 05:25 PM
Registered Member
Old 02-08-2019, 05:26 PM
Steve
BreezyTL's Avatar
Hell I wouldn't even try this. Seems like it is fairly difficult.
BreezyTL is offline
Old 02-08-2019, 05:29 PM
Steve
BreezyTL's Avatar
To fit the TLX the guy probably shaved these parts off and custom fit/cut/shaved to fit the rest.
BreezyTL is offline
Old 02-08-2019, 05:30 PM
Registered Member
I tried contacting one. No answers.
Thanks for your input!
Old 02-08-2019, 08:31 PM
Registered Member
KB1Spec's Avatar
That other person who did the TLX did a front end swap from previous TLX to the current TLX model. If you want to do yours, same issue. Do a full swap front end. Meaning changing front fenders, bumper, hood and maybe headlamp.
Not sure if you are referring to this person
Snapshots: Acura TLX A-Spec Conversion ? Acura Connected
KB1Spec is offline
Old 02-08-2019, 09:43 PM
Registered Member
this is the guy im talking about.
Search Results for ?Delete the beak? ? Acura Connected
Old 02-08-2019, 09:46 PM
Registered Member
This guy on Instagram did it too. I’m just trying to figure out the corners on top. And also the bottom. The grill I bought fits inside my current. It should be bigger so I can cut the sides I need.
Old 02-08-2019, 10:30 PM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
You have to change out the entire front end: bumper, lights, etc.
gatrhumpy is offline
The Following User Says Thank You to gatrhumpy For This Useful Post:
37tzee (02-15-2019)
Old 02-09-2019, 08:46 PM
Registered Member
It almost looks like he just kind of leaves the top corners 'blank' and replaces the trim as is. It's a bit more apparent in this pic if you look at the top left corner. Probably takes a bit of hacking/artistic ability lol.
You definitely don't need to replace the entire front end bumper and lights lol, that's just silly. You're going to have to think a little bit out of the box on this. Can't just look at the manual and say you can't do this because parts don't list exact fitment and Honda/Acura say it doesn't work haha.
skarface is offline
Old 02-10-2019, 04:33 AM
4G TL-Elilte, 3G MDX
Looking at the OP's pictures with the new grille superimposed on the existing grille, it is very obvious that the two grille are shaped differently, with the shorter new grille narrower up top and wider down bottom and the taller existing grille the other way around.
Therefore, it needs some major customized bodywork in cutting/welding the metal hood as well as the front bumper in order to make the new grille fits perfectly.
I too agree that it is much simpler just by replacing the entire front end that comes equipped with the new grille part.
Edward'TLS is offline
Old 02-10-2019, 07:20 PM
Registered Member
For sure the easiest way would be to replace bumper, lights, fenders, etc. Just way too much money. I prefer to do the mod.
From this picture below below it looks like he just fits it to the trim and goes from there.
Old 02-10-2019, 08:08 PM
Registered Member
It'd be awesome if some aftermarket company could just provide the grille insert. Can't be that hard to just put in diamond pentagon design on all the old Acura shields. There must be a market for that.
skarface is offline
Old 02-15-2019, 09:12 AM
Registered Member
37tzee's Avatar
To make that work on an MDX, you would need to change the entire front end - hood, fenders, bumper cover, and misc under structure. You would be better off just buying a newer MDX. You will never get your money back on resale/trade.
37tzee is offline
Old 02-15-2019, 05:58 PM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Ugh,..
Crashmaster
Fifth Generation TLX (2015+)
24
01-17-2018 03:41 PM
ngravatt
4G TL Photograph Gallery
10-31-2013 08:52 PM
PsychDoc
Fourth Generation TL (2009-2014)
06-30-2010 10:40 AM
darth62
23
10-16-2008 10:32 PM
anokha786
Second Generation TL (1999-2003)
07-22-2002 03:36 PM
Quick Reply: Beak removal help
