Suspension tuning mdx
Old 12-14-2018, 06:20 AM
shenofjo's Avatar
I know it isnprobably not sOmething 99% of the mdx owners are thinking about doing. I am generally impressed with my 2014 mdx drive train, linear powerplant and sh awd in corner turn in while on power through torque vectoring. Overall the suspension is sporty on road surface feel already. What i am looking at for improvement is the car lean in tight corner turns and side to side roll when changing direction on freeway speeds. Naturally the BC coilovers are on the list, but i wonder if anti sway bars or other components may be more helpful. Coilover users or other suspensiin component users input would be great, thanks.
Old 12-14-2018, 01:00 PM
Cajun Gumbo Man
Fabvsix's Avatar
Active Damper Suspension rids leans/dips etc...…
Old 12-14-2018, 06:35 PM
shenofjo's Avatar
except its impossible to retrofit that and also too much maintenance in the future if it breaks
Old 12-14-2018, 06:45 PM
Received 16,263 Likes on 11,973 Posts
Upgraded thicker sway bars are what you're looking for.
86LXJunker (12-15-2018)
Old 12-16-2018, 07:17 PM
bmoua15's Avatar
I really hope by the time my active shocks need replacing Ill be trading it in lol. So far after putting on 13k I'm happy with the performance.
Old 12-16-2018, 07:30 PM
Cajun Gumbo Man
Fabvsix's Avatar
$978.00 for each...let that sink in.. but it's da best kept secret...
Old 12-16-2018, 07:31 PM
bmoua15's Avatar
Worth every corner and on/off ramp
Old 12-17-2018, 10:47 PM
shenofjo's Avatar
Not having any success finding aftermarket sway bars or any other suspension parts for that matter... perhaps the BC coilovers are the one and only option.
Old 12-18-2018, 05:05 PM
bmoua15's Avatar
Megan Racing makes full coilovers for 2014+ Models. I've never had experience with their products but the quality seems to be mid grade.
I would look into a wider wheel with sticker tires.
Old 12-19-2018, 03:44 AM
shenofjo's Avatar
what about the wider wheels make you think it would make the handling characteristics change to my preference? surely, I can look into lighter wheels to reduce rotational weight. having slightly smaller offset will push the wheels outward a little more which can give it more planted feel and slightly slower steering. I wouldnt mind the steering change as the oem in sport mode is well weighted but slightly twitchy in terms of too fast of steering to minor input.
sticking to oem size would make the wheels lighter than say 19x9.5". the other forum member used 20x10" wheels and even though the weight was the same to stock wheel/tire combo, he felt slower acceleration with it. I wonder if having increased width and contact patch equated to slower acceleration. this is very small sample size and also the opinion of 1 so its hard to base off of that info.
Interestingly on mightycarmods on youtube, they did a apples to apples comparison of brz/ae86 with good tires vs coilovers, the good tires made a bigger difference on the track, while the good tire + coilovers did best. perhaps I should do wheels and tires first and see if that is enough to get the car to handle the way i want it to before the coilovers. at 43k miles, the shocks feel adequate at the moment.
Old 12-20-2018, 07:01 PM
bmoua15's Avatar
ASpec wheels with Pilot Super Sports is what I would do. Shocks and springs or full coilovers is out of the question.
Old 12-21-2018, 02:38 AM
shenofjo's Avatar
TFR enkei wheels
looking at these 19x9.5" concave wheels from enkei tuning as they are pretty light at ~21lb vs ~29lb oem wheels. Enkei are known for being strong as well. offset is +35 though and not sure how it would look in terms of sticking out compared to oem offset which i am not sure what it is. It is exciting to think this would save 30+lb in rotational weight and an interesting copper on black mdx combo.
Old 12-21-2018, 07:54 AM
Donn0128's Avatar
Be very very careful of offsets. Offset wheels can place an adverse load on bearings and other suspensions components.
Old 12-21-2018, 02:19 PM
bmoua15's Avatar
TFR enkei wheels
9.5 wide wheels with a 35 offset should be flushed with your fenders. Try searching for a photo
Old 12-22-2018, 02:28 AM
shenofjo's Avatar
Wheel tire comparison
found the oem to be 19x8" +55 offset! Compared to the TFR, it seems pretty close to ideal; increased width compensating for decreased offset. It wont be easy finding mdx with any aftermarket wheels let alone these specific ones.
Bobs Yeruncle
3G MDX (2014-2020)
12-05-2013 11:42 AM
I hate cars
12-31-2010 02:01 AM
voxboy
06-19-2007 10:14 AM
Subhuman
03-07-2006 09:46 AM
Maxboost
09-21-2003 12:50 PM
Quick Reply: Suspension tuning mdx
