Service B15
Old 04-23-2018, 12:36 PM
coykiam's Avatar
Service B15
So my wife's 17' Tech just turned 14,xxx miles and now showing Service B15. It includes a coolant replacement, Not sure but isn't it too early for coolant replacement?
My previous cars were either 30k miles or 60k miles for coolant. Should I have it done?
Old 04-23-2018, 12:45 PM
Received 16,266 Likes on 11,974 Posts
I mean; it's never to early to swap fluids...
fresh fluids ONLY help the car.
I guess it would depend on you and your wallet and how long you're going to keep the MDX...if keeping records by Acura helps you with warranty claims...then do it.
if you dont care about the warranty, or can keep records on your own...do it later.
Old 04-23-2018, 12:53 PM
mrgold35
mrgold35's Avatar
Received 1,532 Likes on 1,193 Posts
Did Acura change the anti freeze formula or service intervals for the coolant? I don't think I got the "5" code until 100,000 miles for my 06 TSX, 08 RDX, and 11 MDX.
Old 04-23-2018, 02:45 PM
p07r0457's Avatar
14k is way too early to change the coolant.
Are you sure it's not showing B16? That would be what I'd expect the MID to call for, based on age/mileage. The 6 is rear differential fluid.
Old 04-24-2018, 02:46 PM
Data1's Avatar
Yes it is. No you shouldn't.
Old 04-25-2018, 09:14 AM
coykiam's Avatar
Oops! you're right I read it wrong...it is actually showing B16. So its oil change, tire rotation, bunch of fluid check and the "6" is for differential fluid. Any idea how much it will cost?
Just to confirm it is showing Service B16. Ty guys!
Old 04-25-2018, 09:23 AM
p07r0457's Avatar
Dealers set their own price, but here are some estimates:
Low estimate (my local Honda dealer):
B - Oil Change - $39.95
1 - Tire Rotation - $19.95
6 - Rear Diff Fluid - $125.00
Low estimate = $184.90
High estimate (my local Acura dealer):
B - Oil Change - $79.95
1 - Tire Rotation - $29.95
6 - Rear Diff Fluid - $139.95
High estimate = $249.85
"What I do" estimate (DIY):
B - Oil Change - $50.00 (Mobil 1 Extended Performance 0W20 6 qt + Mobil 1 M1-110A filter)
1 - Tire Rotation - $0.00
6 - Rear Diff Fluid - $30.00 (Acura DPSF 3 qt -- you'll have leftovers)
DIY estimate = $80.00
coykiam (04-25-2018)
Old 04-25-2018, 10:57 AM
coykiam's Avatar
awesome..Ty so much!!! I guess I'll be bringing vaseline to the dealer since my wife wants the dealer to do it...
Nodoze2004
01-03-2007 04:58 PM
TLracr
08-26-2003 02:26 PM
rsq123
10-24-2002 10:39 AM
Quick Reply: Service B15
