Rear lower bumper lights
Old 08-30-2014, 11:38 PM
Ccvn0's Avatar
Does anyone know where or how to get the lower bumper instal or get them install?
Old 08-31-2014, 12:38 PM
KB1Spec's Avatar
Are you referring to the bumper reflector?
Old 09-01-2014, 11:08 PM
Ccvn0's Avatar
Yes. But there kinda dummy light plug.
Old 09-02-2014, 03:36 PM
Honda OG
NelsonLee's Avatar
I'm about to take delivery of my MDX and this is the first item I want to address...more along the lines of how to remove them.
What exactly are you trying to do?
Old 09-02-2014, 11:35 PM
Ccvn0's Avatar
I just want to find out how to put lights in there. I look under there are only 4 screws but wire I don't know where to run it from.
Old 09-03-2014, 01:12 AM
Honda OG
NelsonLee's Avatar
I'll be taking a look as soon as I pick up the car so I will report back then.
I think they were meant to be just reflectors though.
Old 09-03-2014, 01:52 AM
6G TLX-S
Edward'TLS's Avatar
Received 1,141 Likes on 816 Posts
Those reflector openings can be used for "rear fog lights" as in some European vehicles.
Old 09-14-2014, 12:55 AM
KB1Spec's Avatar
I thought about doing it by putting some LEDs light as to how I did to my 4G TL until I saw the price of the reflector for the MDX. If I get a spare set it will cost about $130 each.
Old 09-15-2014, 10:00 AM
Honda OG
NelsonLee's Avatar
I crawled under the car and noticed that it's held in by a few screws, and what appears to be a bulb holder. I'm sure we can source out the correct plugs, by my concern would be where to tap the power from.
Old 10-19-2014, 12:05 AM
montrealrez's Avatar
I like the idea of LED lights from a previous poster. On the prototype mdx they had LED lights. Looked real good in my opinion. If someone could do such a thing and posted, it would be amazing.
Old 10-19-2014, 01:31 PM
KB1Spec's Avatar
Maybe check here
High Power LED Daytime Running Lights, LED Strip Lights, LED Fog Lights
Old 10-21-2014, 05:54 PM
RSLTSX09XMNAVWX's Avatar
Rear Bumper Reflectors, Acura Made It Easy..
I have scoped out this project and determined that the upper half of the reflector is a Reflector, but the lower half is clear red plastic... Placing high intensity Led’s, 2 rows behind the clear red plastic.
One row is for brake lights or turn signals. The second row is for night time running lights... How to feed power to it!! I will feed it from the power plug that is used to feed the trailer hitch power socket.
You will need to use a volt meter to find the correct pin out, don't have a electrical service manual. If you have the trailer hitch and socket already installed this is very easy..
Not sure if i want to have brake lights or turn signals, leaning towards brake lights.. One row will definitely be nighttime running lights to compliment the rear LED night time running light... Hope this helps...
BTW, the picture of the prototype looks SO NICE!!! If you are going to put Chrome in the back, it needs to go across the entire lower back, not a piece in the middle. The GL350 Benz has it right..
02-25-2020 09:57 AM
space_boy
ILX
51
08-15-2017 12:06 PM
handsom-hustla
11-13-2015 05:04 PM
obsessedmotors
09-10-2015 10:49 AM
ptbarnett
3G RLX (2013+)
08-30-2015 12:39 PM
Quick Reply: Rear lower bumper lights
