Hi All,
I am getting ready to do a tire rotation on my 2015 MDX.
I looked through the manual for safe lifting points so I can lift the car on one side, then put stands on one side of the car to complete a tire rotation (front to back).
All I could find in the manual was the 4 jack points when doing a spare tire change.
jack stand points from owner's manual
Can anyone post pix of safe lifting points when using a floor jack or the scissor jack to lift the car so we can place the jack stands?
There is one spot that will work on all sedans when lifting both wheels of the ground from the side and that is directly below the center door post on the pinch weld.
Be sure to place a 2"x4"x2' board on top of the jack to protect the pinch weld when lifting at this spot.
Unfortunately for you, your MDX's rocker molding is in the way, unless you can loosen the bottom of the molding and get access to that area.
