Fuel nozzle getting stuck
Hi,
My 2017 MDX Advance has an issue where the nozzle recently started getting stuck in capless gas filling system and tough to pull out. I will ask the service person however wonder if anyone has run into this kind of issue ?
Thanks,
GS
Thanks,
GS
I haven't see this. However, I do go to stations which have fairly new equipment. I have noticed the pump nozzles have an addition flange which only allows you to put the nozzle part of the way in. That probably helps prevent it from getting stuck and also probably allows for better escape of the fumes. Keep us posted on what you figure out.
Thanks for the response. I took it to the dealer and he ran a test to see if there are leaks or anything else. Looks like its fine. Am yet to refuel to see if its getting stuck again. Will keep posted here.
GS
GS
