Diagnosis Help, please ...
Old May 23, 2020 | 10:08 AM
jeffa624's Avatar
3rd Gear
Exclamation Diagnosis Help, please ...
While traveling at high speed on the interstate on Thursday, my 2017 MDX dashboard lit up like a Christmas tree and stalled out such that I had to coast off the to the shoulder and get towed. The errors included Electric Parking Break Error, Emissions Error, Transmissions error , etc. but, naturally, the errors were gone when the mechanic checked it out and, for some reason, there was no computer record/history that these errors had occurred.
Ultimately, I was able drive the car home, but then it happened all over again yesterday while waiting in line for a car wash. I took a quick video, but I cannot seem to figure out how to post it here.
Any assistance/guidance is appreciated ...
Old May 23, 2020 | 11:15 AM
RLX-Sport Hybrid's Avatar
I would not be surprised if it had something to do with a weak battery (12v).
Old May 23, 2020 | 11:18 AM
GrebRL's Avatar
Greb 06 RL
I think I saw a TSB on that symptom, it involve a fuse or CB or relay that Acura found to be the cause. I can't find it now but your service advisor might help find that TSB.
Old May 23, 2020 | 11:51 AM
jeffa624's Avatar
3rd Gear
Thank you.
Old May 23, 2020 | 02:38 PM
GrebRL's Avatar
Greb 06 RL
I found it! It is TSB 19-005 titled "Multiple indicators on and optional fuse (E21 or B7) blown" I copied the symptoms below
Service Bulletin 19-005
March 7, 2019 Version 2
Multiple Indicators On and Option Fuse (E21 or B7) Blown
Supersedes 19-005, dated February 19, 2019, to revise the information highlighted in yellow
AFFECTED VEHICLES
Year Model Trim VIN Range
2016-19 MDX ALL ALL
2017-19 MDX Sport
Hybrid
ALL ALL
2018-19 TLX V6 ALL
REVISION SUMMARY
• Under AFFECTED VEHICLES, models and were added.
• 2018-19 TLX information was added.
SYMPTOM
The vehicle may exhibit several of the following symptoms:
• Multiple indicators are on.
• No communication with the i-HDS.
• The option fuse (7.5 A) is blown.
– MDX: Fuse E21
– TLX: Fuse B7
• MDX: It is hard to shut off the engine.
• TLX: The transmission will not shift from park.
Old May 23, 2020 | 03:20 PM
jeffa624's Avatar
3rd Gear
Wow. Thank you!
Old May 27, 2020 | 06:07 AM
acuratech481's Avatar
There's a fuel pump recall for these and TLX's... (S/B 19-011) I would bring it to Acura if you haven't had that done. There's a software update and if it stalled and set an on-board snapshot for 'Engine Stall 2' it also needs a fuel pump.
S/B 19-005 doesn't apply as stalling is NOT one of the symptoms listed.
Old May 30, 2020 | 09:33 AM
NVAKeith's Avatar
Acuratech thanks for sharing that. Sounds similar to a stalling problem my mom had with her 2016 V6 Accord when it was a year old. Sure enough, same bulletin exists for the Accord:
https://static.nhtsa.gov/odi/rcl/201...9V060-2834.pdf
neuronbob
3G MDX (2014-2020)
Mar 29, 2017 03:30 PM
Skirmich
1/2G MDX (2001-2013)
Apr 24, 2016 04:13 PM
007Acura
Jan 24, 2009 09:57 AM
