2016 MDX oil change
Old Jan 29, 2017 | 12:05 PM
nv269's Avatar
2016 MDX oil change
Hi,
i changed the oil and i am a bit confused on the oil stick reading, i used a 5 quartz and a little bit more to get it to 5.7, is the .7 that i am having a hard time, see the picture, the oil stick is not fully covering above the recommended but there is some oil over the cover mark, did it put too much, i keep putting it in and i keep reading the same, the car has not ran since yesterday, i would think if i added more oil that the whole stick will be cover but it is not, half way is covered, what are your thoughts?
Old Jan 29, 2017 | 03:29 PM
jzhu625's Avatar
i normally put 6 qt with filter changed.
Old Jan 29, 2017 | 04:21 PM
nv269's Avatar
Thanks for the reply, I will keep an eye on it.
Old Jan 31, 2017 | 06:08 AM
hondu's Avatar
That looks full to me. You have oil at the max mark on the dipstick. I normally put 5.7 quarts in and it reads full.
Old Jan 31, 2017 | 06:20 AM
I also agree! It's a tick over the max mark! but that's okay and PERFECTLY fine!!!
Enjoy your MDX! !
Old Jan 31, 2017 | 08:01 AM
nvasquez269's Avatar
Thank you for replying, it is just hard to keep adding and making sure you don't over fill it.
Old Apr 25, 2017 | 06:05 AM
korbo's Avatar
Make sure that when you are reading the oil level the engine has had time to drain the oil back into the oil pan. If you read it immediately after shutting the engine off, it will read a below the 1/2 way mark.
Lorraines TLX
New Member Introductions
Jan 31, 2017 09:39 AM
Carbon Legend
Nov 25, 2016 01:50 AM
dregsfan
Nov 13, 2016 10:10 AM
dganesar
Oct 27, 2016 07:49 PM
Eric7770
Oct 14, 2016 06:22 PM
