Will these fit?
Will these fit?
Will these specs fit on our cars? Im a little unsure about the 38 offset. I read somewhere that 38 might work, I just cant remember where. I know the next question might be, "depends on what look you are going for" and i do intend to drop (tein Htech). IM hoping to get the wheels to sit flush with my fenders (stance look)? thanks for the help.
The wheel size is 19 x 8.5. So I guess it would be sucked in a little? I should've posted this link earlier. I'm looking into getting this set-up. http://www.wheeldude.com/catalog/pro...oducts_id=5864
They are geared more for BMW and Lexus. This set was the closest I could find. I'm assuming being sucked in, spacers could solve that problem, right? If so, what are the cons of running spacers.
8.5 wide +38 will be very much in line with the fenders, maybe a tad inside, but almost perfect. If you want it more "flush", a 5 mm spacer in the rear will work, but you might get rubbing depending on tire size and drop. I say leave the fronts as is.
Use the calculators in the thread linked in post #5, you'll learn more about fitment that way and won't have to rely solely on others' advice.
i have these in a +35 offset and my fronts poke out about 1 or 2 mm...the +38 offset will be great for the front and the rears will definitely tuck in. the Htech springs are not low enough imo and you will have a gap between the tire and the fender. depending on your financial situation, go with s.techs or coils...
Guys, im super confused on offset and fitment. I read the guides. But after reading a bunch of posts, everyone seems contradicting. I was set on Drag DR37 cheap, they only come in 40 offset. https://acurazine.com/forums/2g-tsx-photograph-gallery-144/dr37-shoes-falken-wrapped-851303/
but 40 sticks out the front a little?
Im doing 225 40 19 eibachs. i want the wheel to be flush, if not slightly inside.
35mm front to keep it IN a little, 40mm in the back???
emailnatec
29
Sep 28, 2018 04:27 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
