will this fit?
Old Jun 17, 2009 | 09:02 PM
bonjyng's Avatar
will this fit?
will this rim setup fit our 2g tsx? also, will it have rubbing issues once i put on the tein s springs? thank you
Wheel Size: 19x8, offset is 51mm
Bolt Pattern: 5x114.3
Old Jun 18, 2009 | 09:09 AM
Tishkevich's Avatar
yes, no rubbing issues
Old Jun 22, 2009 | 04:46 PM
ruel369's Avatar
i have the same question with bonjyng: will this fit?
wheel size: 19x8.5
offset: 40mm
tire size: 255x35x19
bolt pattern: 5x114.3
any rubbing issue after lowered... ty.
Old Jun 22, 2009 | 06:50 PM
Tishkevich's Avatar
I have 19x 8 48 off set same bolt pattern same tires and have no rubbing issues i'm lowered as well
https://acurazine.com/forums/2g-tsx-photograph-gallery-144/black-tsx-730460/
RJ is also about to sell me a set of 19 x 8.5's and claims no rubbing issues as well with the same offset, so I believe you'll be just fine.
Old Jun 22, 2009 | 07:12 PM
ed_423's Avatar
SeeYou2Crew #2
how mcuh did u lower? from this angle it doesnt seem its lowered much haha
Old Jun 22, 2009 | 07:13 PM
HeavyDuty's Avatar
WTH happened to my garage
I would guess RJ will chime in shortly, but there *can* be issues with the design of the spokes that *could* prevent the right diameter/offset from fitting a car *exactly*...so check fitment from the manufacturer.
Old Jun 22, 2009 | 10:48 PM
bonjyng's Avatar
heres another option im looking at:
http://lasvegas.craigslist.org/pts/1233320692.html
specs:
5x114.3
70.5 hub diameter
53 offset
what you guys think?
Old Jun 23, 2009 | 06:49 AM
Tishkevich's Avatar
its lowered 1.2 int he front 1 in the back.. but its more like 2 in the back and 1.2 in the front lol
Old Jun 23, 2009 | 07:39 PM
ed_423's Avatar
SeeYou2Crew #2
lol if u didnt lower it would the gap between of the 19s be big?
Old Jun 24, 2009 | 06:55 AM
Tishkevich's Avatar
yep. looks raised when you put bigger wheels on it and don't lower it. I pretty much just rbought it down to stock height. but it still looks lowered to most people
emailnatec
29
Sep 28, 2018 04:27 PM
vpasla1
Sep 17, 2016 07:24 PM
ROWDY621
Sep 30, 2015 03:20 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
Bielikb96
Sep 28, 2015 10:45 AM
