Wheels size limit question.
Hi,
I am an owner of an 2012 TSX Base 6spd. I want to know if I can install 16inch wheels for the winter set-up? In example.. does RSX 16inch wheels would fit?
Thank you for your help.
Guillaume
Guillaume
If the bolt pattern and CB of the rims match up with your TSX, I believe fitment is fine per se. Since these are for winter, I assume you'll be running higher profile tires (50-60 profile). If you don't, your car will be lower than stock because you've gone down an inch in diameter in your wheels.
If you care about aesthetics, I suggest going for a minimum of 17" wheels, even for winter. 16" wheels are unheard of on this forum (even for a winter setup), and I think they're gonna look super puny on the 2G TSX, even with a thicker tire.
nuldabz
Sep 3, 2015 05:49 PM
Mugen TSX
Eastern Canada
Sep 1, 2015 11:05 PM
