TPMS Low Pressure Warning
Old 05-15-2011 | 05:02 PM
james_and7's Avatar
I installed some TPMS sensors into my after market wheels in February and since the day of installation, the front passenger sensor read 20 Kpa lower than the rest (222 Kpa). Today, I got a warning light saying i have low tire pressure and when i check the dash, it says its at 188Kpa while the rest of the tires are at 240 Kpa. When checking the pressure manually, all 4 tires are aound 34 Psi.
Any ideas?
Old 05-16-2011 | 09:43 AM
DJPlayer's Avatar
I'm not expert at this.. (been doing my research into the TPMS's though). You said you installed TPMS sensors? what kinds? OEM for 2nd TSX? MDX? generic name brand etc..?
Old 05-16-2011 | 01:10 PM
james_and7's Avatar
They are OEM and apparently came from a RDX.
Old 05-16-2011 | 07:26 PM
ttk5's Avatar
Vancouver B.C.
Apparently the RDX ones are not consistently operational with the TSX. Some people have had no problems, while others like you experiences problems. :S ..Im not sure man
Old 05-17-2011 | 01:00 AM
09TSXTech's Avatar
Sorry to hear about the problem, looks like a malfunctioning sensor.
Try rotate the front passenger tire to the back and back to the front. If problem persist (ie low reading showing on rear tire afterwards), then you need to replace the sensor, otherwise it's the TPMS receiving unit in the front wheel well.
Mike Pilipenko
03-26-2024 10:21 PM
johnalfa
11-05-2015 07:44 PM
blacktsxwagon
10-27-2015 11:12 PM
RobbDizzle
10-15-2015 12:16 PM
detailersdomain
Wash & Wax
10-09-2015 11:13 PM
Quick Reply: TPMS Low Pressure Warning
