SPC rear camber kits now out
Patiently waiting ...
I saw this on DriveAccord (very similar suspension setup to the TSX).
SPC has now released rear camber, rear toe, and rear setback adjustable arms. Rear camber arm alone will do +/- 1 deg. camber; all three together will do +/- 3 deg. camber.
Here's the part numbers
Camber: 67545
Toe: 67555
Setback: 67550
All three: 67540
I found some on ebay, I'd like to see what those with Eibachs and Progress springs only (on stock struts) would achieve with this setup....
Camber: 67545
Toe: 67555
Setback: 67550
All three: 67540
And btw, here's the installation instructions
http://spcalignment.com/PROD_DIR/SPC...txt&cmd2=67545
http://spcalignment.com/PROD_DIR/SPC...txt&cmd2=67540
i'mv very interested int his threat my self been lookin for this answer for a while, I found the same thign on EBAY a few months back but I wasn't sure if I should trust it. Has anyone used them yet? I personally have -3.4 on the left rear wheel and -2.5 on the right rear wheel So I need these to stick it at about 2 degrees on both.
BTW, Custom Alingment in the SF Bay Area does great high end work and they really like SPC products.
I found the SPC camber kit 67540 for $245 at http://www.corsportusa.com/store/catalog/product_info.php?products_id=4423
Depending on what camber kit you install it includes suspesion linkage that allows the camber, toe and caster to be adjustable. When you lower the car the alignment changes. On the rear of the TSX Toe is the only factory adjustment that can be made without adding an after market kit. The more you lower the car the more likely you'll need to add a kit. I just lowered my car ~1" and it doesn't look like the kit will be needed.
OK just put on my wheels today, got wheel aligned they obviously tried to correct my camber... which means no more negative, which means they didn't lower it enough for my liking... with 20 inch would you think i'll need the assist of a camber kit so i can lower it a bit more to make sure it won't rub the guard, cause right now it's kind of sitting straight almost with a slight negative and it's lined up with the wheel arch guard... right on the edge.
you can either lower it or buy a camber kit and push it out another degree.. I know for me i was at -3 degrees camber with a 1 inch drop.. so I can only image what I'm at now slammed.. I bought a 1 degree camber arm. and I plan on correcting it but iw as looking at the wheel clearance and i'm not sure if my 19 +32's will clear if I push it out any farther like your case..
Camber isn't what kills tires, toe is
Just got my friend to lower my car a bit more... i like the height now, but there might be rubbing issues if i go over bumpy roads quick lol MIGHT, i certainly hope not *touch wood*
09-04-2015 08:03 AM
nuldabz
09-03-2015 05:49 PM
