NOOB BC Coilovers BBS18x8 + 40mm offset. OK? Tire Size?
Old 04-20-2017, 08:19 PM
BLKOUT714's Avatar
Noob here trying to see if this setup would work
Supension
INSTALLED: BC Coilovers
First do rims fit.
BBS RE
18x8 +40 Offset
Second what tires?
BF GOODRICH g-Force T/A KDW 235/50 18
OR 245/45 18
Old 04-21-2017, 08:40 AM
VTEC just kicked in, yo!
xtcnrice's Avatar
Received 1,112 Likes on 876 Posts
1) Wheels fit.
2) 235/50R18? That's a really thick ass tire IMO, especially on 18s. Would probably not look as weird on 17s. 245/45R18 sounds better, but I have a feeling it will throw the speedometer off quite a bit.
Old 04-21-2017, 08:46 AM
Received 16,260 Likes on 11,971 Posts
245/45/18 will get pretty close to OEM's diameter.
you want to match OEM's rolling diameter, so that your speedometer isnt off.
the 245/45/18s will be 1.35% larger in diameter than stock, so speedo will be off by 1.33% too slow.
but that's okay, as that's the closet to stock diameter....
and use a gawyam tire calculator next time to show and see this info
Old 04-21-2017, 09:00 AM
xtcnrice's Avatar
ah 1.35% off, that's fine
justnspace (04-21-2017)
Old 04-21-2017, 09:02 AM
yeah, the tire calculator said...Actual speed...62mph...245/45 = 61.something mph.
so, likely wont even notice speed difference
Old 04-21-2017, 09:03 AM
the 235/50's were over 3% larger than stock.
and I used the 235 stock number... I hope that's right....
Old 04-21-2017, 11:20 AM
BROlando's Avatar
Received 1,169 Likes on 879 Posts
If OP's car is a 4cyl, then 245/40/18 is the nearest perfect size in terms of diameter. But it will be pinched on 8" wide wheels.
225/45/18 might be better.
