NOOB BC Coilovers BBS18x8 + 40mm offset. OK? Tire Size?
Noob here trying to see if this setup would work
Supension
INSTALLED: BC Coilovers
First do rims fit.
BBS RE
18x8 +40 OffsetSecond what tires?
Supension
First do rims fit.
BBS RE
18x8 +40 Offset
Second what tires?
BF GOODRICH g-Force T/A KDW 235/50 18
OR 245/45 18
VTEC just kicked in, yo!
1) Wheels fit.
2) 235/50R18? That's a really thick ass tire IMO, especially on 18s. Would probably not look as weird on 17s. 245/45R18 sounds better, but I have a feeling it will throw the speedometer off quite a bit.
245/45/18 will get pretty close to OEM's diameter.
you want to match OEM's rolling diameter, so that your speedometer isnt off.
the 245/45/18s will be 1.35% larger in diameter than stock, so speedo will be off by 1.33% too slow.
but that's okay, as that's the closet to stock diameter....
and use a gawyam tire calculator next time to show and see this info
justnspace (04-21-2017)
