Newb suspension questions
Let me preface this thread with: "Never messed around with suspension set ups before."
I'm trying to determine if Koni sports with s-techs or pro-kits OR a nice set of coilovers would be the way to go?
Don't shoot me for asking this, but I haven't gotten direct clarification... Is a coilover basically a strut with spring and assembled? Implying there isn't really a big difference between the end product of either combination?
My goals are to eliminate some wheel gap, better overall handling, minimal bounce but not producing a stiff ride the girlfriend will hate on. The coilovers seem to include all parts necessary to install, whereas if I buy konis and springs I still need to replace the other components, like the top hats, dust boots, etc. I also saw the Teins with the pillowball upper mount claim to increase steering feedback, which sounds like something I would want because I'm not a huge fan of the stock steering feel.
On a side note, I'd like to also get a better RSB.
Please let your communal knowledge rain down upon me.
The basics:
Coilovers are a strut and spring, but depending on make/model, some still require you to reuse your OEM top hat to complete assembly. Coils allow for unlimited height adjustment. Some offer dampening and rebound adjustment of the strut too. Con I can think of: 1) Rust can end all adjustability. 2) You really get what you pay for.
Koni's + XXXX spring allow for one ride height (whatever the spring gives you), but the Koni yellow for our platform has two mounting perches so you can drop a few mm more, so you essentially have "2". Koni Yellows also give you adjustability of dampening. Think stock strut + lowering spring, but better quality and you can soften/stiffen the dampening. Cons 1) Can't adjust height. 2) Price.
Progress and ST makes rear sway bays. Progress is probably the more favorable one. Saw a thread of someone swapping over a 4th gen TL rear sway too.
Others can chime in ...
t3hhcaptain (04-07-2016)
I saw UL makes one too. I was leaning towards the progress, mainly because I have seen and heard good things about them before.
Honestly, I probably don't need the ability to adjust height, though I wouldn't be upset if I could.
Koni's have that 1,000,000 mile warranty, where all the coilovers I've seen have 1 year.
With the tein coilovers, I would be able to adjust dampening and height, and would have the pillowball upper mount that I'm curious about. Does anyone have feedback on the pillowball?
xtcnrice (04-07-2016)
Thread revival.
I've decided I'm going to run Koni sports and eibach pro-kit. I'll be ordering and installing them in September.
My plan is to also get all new OEM hardware (mounts, bolts, etc) and have them preassembled for the install.
One of the steps in the service manual for installing shocks is to jack up the suspension to put the weight of the car on it. Can anyone chime in on this?
For those that are willing to actually provide some assistance, I am referring to step 7 for installation on page 18-27: "Place a floor jack under the lower arm, and raise the suspension to load it with the vehicle’s weight."
On the record, videos I have seen of folks doing suspension work have not had a step like this. Simply remounting the shock and tightening everything up.
Step 10 here: https://acurazine.com/forums/2g-tsx-...hile-i-928923/ seems to answer my question.
cu2wagon (08-15-2016)
Received 7,772 Likes
Roland_Bluntzs instructions that cap'n posted is what you need. So thorough.
The following 2 users liked this post by cu2wagon:
t3hhcaptain (08-15-2016),
xtcnrice (08-15-2016)
there's more than one way to skin a cat.
if you are by yourself, that would be one way to "compress" the springs in order to get the shock out of shock tower area.
or you can enlist a bunch of friends to jump on the control arm while you wiggle out the shock...
or you can use a prybar or a breaker bar to PRY the control arm in order to wiggle out the shock.
the main objective is to get the shock out and you wont be able to do it without doing one of the three I listed because control arm, and other shit is in the way.
ILLustriousUA6
03-10-2016 08:55 PM
