Just pick them up a set of Vossen Wheels!!!
#81
takin care of Business in
Received 4,732 Likes
you guys on the TSX forum are -in'
#82
The following 2 users liked this post by chaqui74:
LowNslo TypeS (05-15-2012),
VortexBlueTSX (04-12-2012)
#89
rockstar143 (04-17-2012)
#90
Purchased my coils from mark also, great guy to deal with.
#95
Should you get tints?!?!
Easy answer, it's under your avatar...
OF COURSE YOU SHOULD GET TINTS!
Best tints ever...go to JR Electronics on Bird and 94th...have Jose do them...I've never seen such a perfect line so close to the edge of the glass. Also, had a bubble develop like 3 years later (my own fault...non oem visor) and they redid it with no questions asked.
#96
Yes get tints, but keep them light.
Mark -- I am coming for you. I know where you live now. LOL.
No really, I have a (short list) of stuff I need. Not sure what you have access to. But my deadline for an exhaust and intake is next Honda Day. WEPA. Lets see if it gets done. (Knowing me, probably not. LOL)
Chaqui. - I don't like you anymore. =[ Lol. I kid. :Hug:
#97
am waiting for Rockstar to reply to Kait
ed_423 (04-18-2012)
#98
Wow, that looks aggressive. I like it. But as much as I like the look, I am not going this route. Lowering and rims like the Vossens are too much for my daily driver TSX. I will stick with stock height and 19" RDX wheels. After all, I do have a 2000 Xtreme S10 lowered for that kind of fix. But your ride is pimp!
#99
Looks great! Thinking about imitating your set up. Someone is selling on CL a set of vossens with the below specs? Will it work with just a roll? Or will I need more work done to make it fit. Oh and I do not want to lower it. Not sure if that will help or hurt my cause.
Thanks for the help!
Specs:
Wheel size is 20x10.5 all around with a +42 offset.
Tires are NANKANG nsII 255/30zr20 rear, 235/35zr20 front.
Specs:
#100
Man I was going to go with 10.5 up front but after seeing the X9 +38 I was like hmmm 10.5 will require pulling which I wasn't looking for that, but the rear roll and trim the bumper (depending how low you go)
Specs:
Specs:
#101
Specs:
Specs:
#107
Hey Chaqui, your fitment looks great. I plugged in your wheel and tire specs into will they fit.com and it looks like your rear wheel is about 1 inch closer to the strut than the stock wheel. It also looks like your front wheel is only 2mm closer to the strut as compared to the stock wheel. I measured the distance between the inner wall of my front wheel and the strut and it was 1 to 1.5 inches (my car is not lowered). Will I have any problems if I lower my car 1 to 2 inches in the front and have a wheel that is .5 inches or 12.7 mm closer to the strut than the stock wheel?
Was there a reason why you chose to get a wheel size that was closer to the suspension strut in the rear than it was in the front? Will I run into problems if I lower my car and get wheels for the front that are closer to the suspension struts than the stock wheels?
braveheart
09-07-2015 08:12 AM
