any issues with 19x9.5 or 19x10 all around?
Old Dec 30, 2010 | 08:03 PM
defconskylude's Avatar
im going to go with a concave look and was wondering if i would face any issues if all 4 rims where 19x9.5 all around or even 19x10 all around?
thanks!
Old Dec 31, 2010 | 12:01 AM
24boosted's Avatar
You would need to know the offsets, tires, face design in addition to width to figure out whether you will have problems. High offsets with a wide width rim and you will have suspension rubbing issues instead of fender rubbage. It's not just the width but a combination of the rim spec that would cause issues. These are my Volk GTC's two wheels (back two) are Face II which has more concavity than Face I. Depending on the wheel manufacturer, for example like Ray's makes wheels with different faces. There are 19x10 Face I with flat spokes while others like mine 19x9.5 have concavity.
Old Dec 31, 2010 | 12:19 AM
24boosted's Avatar
Damn still editting and it locked me out. You could get a x9 wheel and still have concavity it all depends on the manufacturer. You could have a x8 wheel and have rubbing issues if the offsets are low enough. MB Battles AKA CSTs are dirt cheap and super concave in almost any width or offset.
Old Dec 31, 2010 | 04:27 PM
im going with the VB3
im going 19x8.5 on the front
the guy is finding out if i can fit 19x10 on the rears. its 5x120 and has +25 or +38 offsets with a 72.6 bore. he's going to give me hubcentric rings to fix the centerbore issue.
if i cant get the 19x10 to fit, then ill go with 19x9.5 rears +22 / +33 / +45
Old Dec 31, 2010 | 06:09 PM
ed_423's Avatar
SeeYou2Crew #2
i say 9.5, seeing how nice 24boosted's stance is
Old Jan 1, 2011 | 02:07 AM
24boosted's Avatar
19x10 +25 will stick out quite a bit in the rear, the 19x10 +38 will be almost identical to my wheels but with 15mm less inner clearance. Suspension rubbing is possible with the +38.
Old Jan 3, 2011 | 01:49 AM
What about 19x9.5 in the front?
Old Jan 3, 2011 | 06:56 PM
24boosted's Avatar
9.5 front with a 25 offset will look nearly the same as my 19x9 +22 a -3 mm difference rears as well. With a +38 offset you will be 10mm further into the car front and rear. Either or any of those choices you're probably going to have to roll your fenders. Depending on the size tires and drop.
Old Jan 3, 2011 | 08:26 PM
just bought two VMR VB3's wheels that are 19x9.5 +45 offset
im going to test fit them on the front for clearance. if it fits well then ill buy two more 19x9.5 +45 for the rear
19x8.5 doesnt have enough of a concave look so im going for 9.5 all around
shop told me not to try 19x10
Old Jan 3, 2011 | 09:26 PM
24boosted's Avatar
You have 18x8 +30 right now right? It'll be about the same to the fender in the front as your G35 wheels. It'll only stick out another 4mm compared to those.
Old Jan 4, 2011 | 11:29 AM
yea 18x8 +30
thats good to hear. i dont really mind if theyre tucked in. id be too worried if theyre poking out
Old Jan 5, 2011 | 04:51 PM
what tire size should i go with the 9.5? 245/35/19 or 235/35/19
i really dont want the stretched look nor roll/pull my fenders
Old Jan 6, 2011 | 01:25 PM
Dan00313's Avatar
Go with a 245 if you don't want the stretched look. I'm the same way, and I'd go with the 245.
Old Jan 6, 2011 | 01:30 PM
u got pics?
Old Jan 11, 2011 | 04:01 PM
cjhighway's Avatar
What about the tire pressure sensors? Would those need to be replaced?
Old Jan 12, 2011 | 10:31 AM
yes. either swap them out of your stock tires or buy a 2nd set.
however ive been running without my tpms sensors for over a year. ive gotten used to the 2 checklights being on
Old Jan 12, 2011 | 10:54 AM
Dan00313's Avatar
Do you happen to know how much a second set of sensors go for?
Old Jan 12, 2011 | 11:05 AM
i havent done research on actually buying another set.
but ive seen them minimum like $130 for a set? im just guessing
Old Jan 14, 2011 | 09:12 PM
cjhighway's Avatar
Yea I have a second set too. it was an accident though. I took the sensors off of my 07 Tsx and put them on my current wheels and forgot about it when I sold the car.
lol.
Frathora
Sep 28, 2015 11:29 PM
racersky
Sep 24, 2015 02:42 PM
carz0159
Sep 20, 2015 06:11 PM
acurajj
Sep 19, 2015 03:47 PM
TSX 09
Sep 14, 2015 10:25 AM
