225/45 17's
Normally, winter tires are higher profile, and sometimes they're narrower as well. The higher profile makes sense for more impact absorbtion from potholes, and you get better snow traction from narrower tires. My 2001 Saab 9-5 Aero had 225/45/17 for regular tires, and for winter tires the Tire Rack recommended a 205/55/16 set. Also, if you keep the 17" rims and go to a lower profile (45), you'll throw off the speedometer and odometer, though I'm sure the dealer could recalibrate for the different tire circumference.
On the TSX four cylinder, I'd probably just get the same size as the OEM set. Call Tire Rack for their recommendation.
You want your wheel and tire to be within 3% of stock diameter, 225/45/17 would be 3.41% therefore not suitable.
Use this link to try out: http://www.1010tires.com/tiresizecalculator.asp
Agree with Ned, should stick with the OEM size which is a popular size. If not, try 215/50/17 (only 1.51% difference) and that's the size used for 1G TSX as well and Mazda6.
As has already been mentioned, for winter driving a smaller contact area is required to afford improved traction. I'd suggest that a 55 profile is desirable as the tread width will be less than the same width tyre with a 50 profile.
I think I'd go for a 205/55x17 or 215/55x17. The 205s are the same diameter as the stock 225s but they will be a bit stretched on 7.5s. The 215s are better and, yes, I know the diameter will be increased over the 225/50s (approx. additional 0.5"), but it's not a significant amount. In fact, it''s the same diameter as the 235/45x18s fitted to the Type S in Europe.
Also, be aware that different tyre manufacturer's products vary in width & diameter, even though they are the same nominal size. Get the data from your current tyre and then use that to choose the lowest diameter 215/55 available from an alternative manufacturer.
Gregory_20706
07-20-2006 10:48 AM
LouSFO
06-05-2005 11:31 PM
Shoofin
04-16-2001 10:42 AM
