water damaging interior HELP.!
Old Dec 16, 2014 | 10:50 PM
smashn.kev's Avatar
so.cal.cu2
Hello, anybody else getting water damage on the passenger side carpet possibility that it's coming from underneath the car.? Car is lowered on twin basic maxed (we all know it's not low) but haven't driven the car in the rain either any help is much appreciated. Thanks in advance.
Old Dec 17, 2014 | 07:25 AM
ceb's Avatar
ceb
Clogged drain - either AC or sunroof
thunderbt3's Avatar
Check if your AC condensation drain tube is clogged?
Old Dec 18, 2014 | 07:02 AM
BlackNsexy2010's Avatar
I just had this issue...when u make left turns and ur ac is running do u hear like a swooshing noise.. Sounds like water is moving around? If so it's probably the ac drain pipe..
If you lift up the passenger side carpet..in the top left corner you will see a black plug going into the floor.. Pull it out..it's pretty easy to pull out..just use your hands and kind of loosen up the bottom then pull it out..I wouldn't grab the tube itself In case you rip it ..then shoot compressed air up it.. Make sure to keep a pan near by because water will flow out.. U can also put the car on lift and go from underneath the car.
U can buy the air In a can or go to any shop..
Old Oct 29, 2019 | 05:36 PM
netsx04's Avatar
What did you end up doing to resolve the problem? I'm having a similar issue from the moonroof drains clogging.
pstomps
Feb 20, 2017 03:29 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
STL TL-S
Sep 23, 2015 08:52 PM
Sep 14, 2015 10:09 PM
oyayjoe
Sep 12, 2015 04:40 PM
