water damaging interior HELP.!
Hello, anybody else getting water damage on the passenger side carpet possibility that it's coming from underneath the car.? Car is lowered on twin basic maxed (we all know it's not low) but haven't driven the car in the rain either any help is much appreciated. Thanks in advance.
I just had this issue...when u make left turns and ur ac is running do u hear like a swooshing noise.. Sounds like water is moving around? If so it's probably the ac drain pipe..
If you lift up the passenger side carpet..in the top left corner you will see a black plug going into the floor.. Pull it out..it's pretty easy to pull out..just use your hands and kind of loosen up the bottom then pull it out..I wouldn't grab the tube itself In case you rip it ..then shoot compressed air up it.. Make sure to keep a pan near by because water will flow out.. U can also put the car on lift and go from underneath the car.
U can buy the air In a can or go to any shop..
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
STL TL-S
09-23-2015 08:52 PM
oyayjoe
09-12-2015 04:40 PM
