VSA button no longer works
Old Dec 24, 2009 | 08:41 AM
bjohnston115's Avatar
Snow here, and i find that if my wheels start to spin i turn off the vsa and i am able to get my car unstuck. So the other day my tire pressure monitor told me the tires were low and and that same day i tried to turn off the VSA but the button no longer turns it off. Is this related to the low pressure or is the vsa messed up??
Old Dec 24, 2009 | 09:53 AM
thunderbt3's Avatar
did you try pressing and holding the button? or just pressing the button?
The manual states press and hold the button for 3 seconds to disable VSA
Old Dec 26, 2009 | 08:35 PM
Supreme's Avatar
i believe it is due to low tire pressure. when my light for low pressure blinked on, my vsa button was basically disabled. once the dealer put more pressure into my tires for me, i was able to turn vsa on or off.
Old Dec 27, 2009 | 09:59 PM
levistar's Avatar
The VSA will not disable when a low tire is detected or there is a fault with a sensor.
Old Dec 27, 2009 | 10:02 PM
levistar's Avatar
You had to have the dealer put air in your tires.
Old Dec 28, 2009 | 09:39 AM
yep you guys are right.. Once the tire pressure warning went off the vsa worked agian. Thanks for the input.
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
cycdaniel
Dec 17, 2019 10:58 AM
acurajj
Sep 19, 2015 03:47 PM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
