V6 Tranny Fluid Change
Old May 21, 2012 | 08:27 AM
TSXV6Guy's Avatar
I decided to replace My 2010 V6's tranny fluid. The dipstick always showed a proper level (I used Honda's fluid check procedure: warm-up car, turn engine off and then check fluid).
Now I remove the ATF drain bold... No fluid drained!!! I was as if the tranny was empty even though the dipstick showed FULL.
I decided to add half a quart of ATF through the fill hole (the V6 has a separate ATF fill bolt on the top of the tranny. Still no fluid was released from the drain!
I did check in the service manual and I am removing the proper ATF bolt according to the illustrations!
Any ideas as to what's going on? No one has touched the tranny fluid before (it's the factory fill).
Old May 21, 2012 | 10:53 AM
TSXV6Guy's Avatar
Disregard this... I was removing the wrong drain bolt: there is another bolt very similar to the drain bolt, on the side of the tranny. I guess I should have used my brain more, rather than follow exactly the manual's instructions. The lack of a magnet on the bolt I was removing should have clued me.
mada51589
Jan 9, 2025 04:40 PM
Yikes
May 3, 2021 04:29 PM
ghuns
Sep 16, 2015 04:26 PM
Aleax
Sep 11, 2015 11:31 AM
HeloDown
Sep 8, 2015 06:51 PM
