Traction control and 6-Speed Manual Question...
Just curious if this is what happens to anyone else who has a manual. Say your driving in the rain, and you stop at an intersection. You start to go and realize someone is coming rather fast from your right, you step on the gas, the car starts to go, but then, the wheels start to slip, the traction control kicks in, and the system completely shuts down the throttle. It doesn't do like the Auto Versions I've driven where it seems to claw for traction and basically go as fast as it can possibly go given it's situation.
Instead, it literally feels like if you were to, on dry ground, floor it and then completely lift your foot off the pedal. IT's actually scary because the harder you push on the pedal, NOTHING happens, it just continues SLOWLY across the intersection. Is this something that happens to other Manual drivers or is something up with my car?
The earlier traction control systems are really intrusive. Thats the same thing that happens in the 04TL 6mt in snow. It cuts ignition to the point of the car stalling. I've had to turn of VSA really quick to prevent that from happening. All you can do it either feather the throttle to prevent VSA from kicking in and allow the car to accelerate or turn VSA off before you think you're going to have a problem.
Thats just my solution though. I've had to stop midway on a hill to turn off the VSA and then slowly feather the throttle to let the car figure it out.
Also with the Torsen you don't get a true LSD so the wheels slip pretty bad, but when you apply steering angle it distributes the power between both the wheels. It takes knowing the system to be able to take advantage of its benefits. So gradually accelerating through a corner would work great on our cars.
Mine literally is like you went from full throttle to completely closed. Just seems like a safety concern given that it doesn't recover from this fully closed throttle all the way across the intersection. It's like having no acceleration at all. And it lasts for a while, I've duplicated it with my buddy in the car and he has a 2011 Civic Si and his car doesn't behave that way at all, might be the LSD helping but even still, seems like the TSX is really dangerous.
I'm not trying to sound like a dick
but if you are full throttle and breaking traction, traction control is going to respond in kind to reduce the excess wheelspin even if that includes cutting out the throttle for a short time period to allow the regaining of traction, the system isn't bulletproof though. That's just my perspective though on why it'd be doing that to you
or it's just broken? lol
The thing is I have had a loaner TSX in auto and 4 cylinder and it doesn't do what my car does at all, the auto basically claws it's way to going faster, the 6-MT just seems to be like OH it's slippery, turn off all power and good luck driver if you are are trying to get out of the way of anything. It's like night and day driving the auto vs the manual.
well the automatic transmission has a computer in it too, the traction control system knows this along with the parameters of the transmission and can predict outcomes better as opposed to manual where it all depends on the driver.
my start-up process:
1.) press clutch
2.) turn key
3.) press and hold VSA button
It's a lower powered, FWD sedan and I only use nice season-specific tires. I can imagine very few scenarios where I would want the VSA on as I have also experienced the sharp throttle cut-off, especially when accelerating out of a turn or on uneven surfaces (dry roads in both cases) where loss of control is a nonfactor.
1.) press clutch
2.) turn key
I've learned to just turn the VSA off
mada51589
Jan 9, 2025 04:40 PM
Puma Jim
20
Oct 20, 2016 11:59 AM
joflewbyu2
Oct 8, 2015 11:16 AM
Charlespsu
Sep 2, 2015 09:54 AM
