Squeaks and Rubbing...
Old Jan 17, 2009 | 02:25 PM
arktctr's Avatar
Just venting here, but I got out of my Audi into the TSX because I had thought it would be a well-built and reliable ride that I wouldn't have to worry about much. My initial impression of my Sept build TSX was that it was pretty damn solid in feel...since then, the thing sounds like its coming apart. I have 1200 miles on it and I now have a worsening rear shelf rattle/creak, the passenger front door panels make a rubbing noise, and now this morning, the front dash makes a similar plastic panel rubbing noise when I go over any kind of road imperfection (i.e., raised dots in the lane markings). I just don't get it...a car that started off seemingly solid, is gradually looseing. I have taken it in once for the rear shelf issue which they could not hear (though I heard it again on the way home) and now that these noise have progressed to be blatantly obvious to anyone in the car, I will be taking it in again.
Anyone else have interior panel noises (other than the rear shelf issue discussed elsewhere)?
Old Jan 18, 2009 | 09:22 AM
09TSXMN's Avatar
Oh yeah. . . First of all, my TSX is going in this week for round 2 on the rear parcel shelf "crackling" noise. The regional tech manager says there is no known fix, even though I have sent him all of the threads on this topic.
I have had to slide cotton into the headliner from the sunroof opening above the passenger head, back side to stop a maddening rattle.
I think I had the same noise as you mentioned in the I/P, it was the upper bezel above the gauges that is under the dash pad. I hand squeezed this area and have not had the issue since.
Finally, I have a "wood ball in a cardboard cup" one time strike that sounds like it is coming from the passenger seat. It only happens when a quick upward motion is evident like driving over a strong frost heave. It does not happen when someone is sitting in the seat. I believe it is around the upper seat back where the seat air bag is.
My trunk hinge rubs on the interior carpet panel and leaves a nice "squeek" when closing. I have tried to re-adjust with no luck.
All I can say is that I too was disappointed with the "tightness" of the interior. Very happy with the car otherwise.
Old Jan 18, 2009 | 01:55 PM
LukeaTron's Avatar
Are you sure it's not the seatbelt buckle flopping around?
Old Jan 18, 2009 | 05:28 PM
09TSXMN's Avatar
Yes, I even plugged in the seat belt to see if tension would take it away, which it did not. It could also be the seat belt centrifical retractor in the b-pillar as well but why would it not make the noise if someone is sitting in the seat. Quick jars to the seatback does not replicate it either.
kmawani
Feb 8, 2023 05:09 AM
2012wagon
Sep 29, 2015 04:21 PM
njresendez
Sep 21, 2015 11:23 AM
forrie
Sep 15, 2015 09:57 AM
jliu6789
Sep 8, 2015 08:02 PM
