Squeaking front brake
Old 07-15-2011, 10:15 AM
Haccord09's Avatar
Another problem with this Tsx, The front brake starts to squeak now. Althought i dont know if its still the original pad or not, it does look like there is still alot of pad left. The car has only 21k miles. Do i need to replace the front pad? I just replaced the rear pad, so that should not be a problem. Im really disappointed at the quality of this car. The front pad on my old 2003 honda accord lasted 40k miles and the rear lasted 60k miles with all the local driving.
Old 07-15-2011, 11:31 AM
its rayden's Avatar
squeee squeee squeeeeeeeee.
could be shims causing the squeeeeeeeeeee too. take the car to the dealer to get it checked out.
Old 07-15-2011, 04:52 PM
TSXV6Guy's Avatar
there was a honda tsb on these. can't recall the exact number but it involved replacing the pads with an updated set with different compound and add v-springs to reduce the vibration. I did mine at 3000 miles (did not bother taking it in) and the noise is gone. You need to loop up the right honda pad part number.
Old 07-15-2011, 08:06 PM
rgoldd's Avatar
I will look for the TSB for you if you haven't already found it? I think its like 058 or something. Acura refused to do mine I had to call up client services
Old 07-16-2011, 05:30 AM
TSXV6Guy's Avatar
I found the Honda Accord TSB: 09-096. It had the updated front pad numbers: 45022-TE0-999. It also applies to the Acura TSX.
SO this is the ones you want to use, it comes with the V-springs.
HOWELLiNC
09-10-2015 01:39 PM
08 NBP TL
09-08-2015 08:49 PM
jliu6789
09-08-2015 08:02 PM
mav888
1G RDX (2007-2012)
09-08-2015 11:49 AM
asahrts
09-04-2015 05:55 PM
Quick Reply: Squeaking front brake
