Seatbelt stuck in door
you should probably buy a new car
wow...that's a good job you did right there.
i think the only thing you can do is try to force it open from the inside. there's really no trick to undo what you did. i hope you didn't break anything permanently.
Pull the handle, then push the door HARD. Some kind of sudden hard impact would probably get it open. Also, get a friend to pull at the same time.
That happens to me all the time, the door on mine never got stock though. I bet you that the small black door seal that is a tube around that area of the door will be craked open in that area.
The pic and all the replies remind me of 'There's something about Mary', when Ben Stiller got his balls stuck in his zipper....
Seriously, try both inner and outer door release handle. See which one will unlatch the door a bit then push from the inside (might need a buddy to help you gently pull from the outside too) good luck!
Thanks for all the help but I finally got it open
I pulled the door handles, and push on the doors with all 400 lb of me and my friend. Didnt work the first time, but worked the second time. lol Hopefully done of u guys do what i did lol ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
My seatbelt survived the pounding to
soupi
14
11-15-2015 11:15 AM
