Rattling Sunglasses Compartment
Old Apr 9, 2012 | 05:36 PM
JordanTSX's Avatar
Anyone else have this? Whenever I turn the radio up and there is any bass at all, the sunglasses compartment has this awful plastic rattle with each bass hit that sounds awful.
The speakers on my car sound great but I can never jam out because of this
Thinking I'll see if I can fit one of those anti-sliding little circles somewhere in there or anything like that to absorb the rattle.
Old Apr 9, 2012 | 06:10 PM
ceb's Avatar
ceb
Add some moleskin (felt) to the inside of the compartment to keep stuff inside from rattling and then add just the tiniest amount around the lip where the door latches. You don't need a lot - just enough to keep the door from touching the roof console.
Old Apr 9, 2012 | 09:22 PM
KillerG's Avatar
Op is too busy to care
I had the same issue, my sunglasses were causing it to rattle; I just stopped using that compartment =/
Let us know if it works and if the moleskin pans out
Old Apr 10, 2012 | 11:22 AM
JordanTSX's Avatar
Well I know its not the sunglasses in there because it happens whether or not I have them in there. I have to just hold my finger to it to stop the rattle. Moleskin is exactly what I need probably, thanks ceb
Old Apr 10, 2012 | 05:46 PM
JordanTSX's Avatar
Figured it out. Turns out it isn't the sunglasses compartment, it's the little piece that has all of the garage door opener buttons. Bitch rattles around so much and I haven't got a clue how to get the from rattling besides shoving something in the crack which won't look great.. That thing seems like its just loose and floating in there.
Old Apr 10, 2012 | 06:43 PM
ceb's Avatar
ceb
Still under warranty? Take it to the dealer. If you try to fix and break it it'll be on your dime.
Old Apr 10, 2012 | 07:55 PM
JordanTSX's Avatar
Yeah still under warranty. It just doesn't seem broken though, just seems like a design flaw really. Can someone with a 09 check out their trim piece and see if its firmly seated in there or if it has some movement like mine does before I take it into the dealer? I'm down at school right now and there isn't an Acura dealer in town and I won't have the chance to take it in for a month or so.
Old Apr 10, 2012 | 08:16 PM
ceb's Avatar
ceb
My 2012 is quite tight and that spot doesn't rattle.
Old Apr 10, 2012 | 09:09 PM
JordanTSX's Avatar
well balls.
Old Apr 21, 2012 | 10:12 AM
PointQ's Avatar
Jordan, I have an 09 with the same problem. I might have even posted about it a while back. I'll take a look at that piece and get back to you.
Old Apr 21, 2012 | 10:56 AM
BaoZZeR's Avatar
Same problem! took my car in about 2 weeks ago to get my replacement grille and they stuffed the garage opener thing with felt at no charge.
Old Apr 21, 2012 | 12:40 PM
jendougchanxan's Avatar
7th Gear
Same issue with my '09. Does anyone know Acura part# on their moleskin/felt?
Old Apr 21, 2012 | 01:59 PM
live2hit01's Avatar
I just used some little felt pieces you use to keep furniture from scratching the floor. Had some lying around, work like a charm.
Old May 14, 2012 | 01:52 PM
the_razor's Avatar
same here its bit loose
Old May 16, 2012 | 06:45 PM
T-jay's Avatar
im baaaack!!
I fixed mine by adding a 15” l7 solobaric. Cant here anything now.
Old May 16, 2012 | 07:10 PM
09TSXer's Avatar
/\ lol
Old May 17, 2012 | 06:59 AM
tvac's Avatar
I had this problem also. Used a sliver of chamois and packed it around the edges with an exacto knife edge. No more noise.
Old May 18, 2012 | 12:21 AM
JordanTSX's Avatar
^sounds like what I'm going to end up doing.
Currently have a piece of ripped gum packaging stuffed into it. Looks like shit, but works and was the only thing in the car that I could shove up in there to fix it when I realized what was going on. Now it just stays there.
Can't decide if I feel like taking it into the stealership and complaining and seeing what kind of BS they give me on how it'll be a 2 day fix and what else they break in the process.
Old May 28, 2012 | 11:39 PM
BigD411s's Avatar
Had the same issue, but as KillerG said, it was due to my sunglasses, so I dont use it.
Old Jun 1, 2012 | 06:15 PM
09TSXMayne's Avatar
need to get mine sorted out as well. so annoying.
Dec 7, 2020 05:39 PM
marcelft
Jul 10, 2018 06:17 PM
spoiler900
May 25, 2016 10:16 PM
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
3GTLOwns
Sep 9, 2015 09:51 PM
