Questions about oil consumption issue
Old Oct 23, 2015 | 11:07 AM
  #41
ulrblitzer's Avatar
How many days did the repairs take? And do you know in detail what was replaced under the new TSB?
Old Oct 23, 2015 | 11:20 AM
  #42
t3hhcaptain's Avatar
The TSB spells out what is replaced, but all gaskets, pistons, rings, and other necessary hardware. Bearings are not, unless showing obvious signs of needing replacement.
It took a few days. They didn't drive it much, so I'm giving it a 500 mile break in to seat the rings correctly.
Old Nov 6, 2015 | 10:03 AM
  #43
JoannesRDX's Avatar
6th Gear
My sons 2009 AT TSX just started an oil consumption test and I believe it's losing more than 1 quart every 1000 miles, but here are my questions:
#1: My son had to pay $50 for the oil change and I don't know why he should have to pay since it's their TSB that brings the car to them?
#2: we got the car back and there was at least 1/2 quart too much on the dipstick (at the top of the bend in the dipstick) which obviously would work in Acura's favor when we bring the car back after 1000 miles. Has anyone heard of a dealer fudging the test this way?
I have a call into the service advisor but have not heard back yet. Any help would be appreciated. Thank you.
Mike
Old Nov 6, 2015 | 10:12 AM
  #44
ulrblitzer's Avatar
Both issues have been brought up in a thread.
The cost of the oil change to start the oil consumption needs to be addressed to Acura North America. The local dealer gets little to nothing for warranty work so they will charge for it. They don't know from the start if it'll need the work done. The dealer at the local level would also be losing if we all went in for a free oil change even tho we didn't meet the need for warranty work. Maybe talk to a regional rep to get Acura to reimburse the cost if the vehicle indeed does get approved for the repairs.
Someone else complained about getting too much oil to start the consumption. They will question if you know how to read a dip stick. Complain to the service dept, ask for a manager if nothing comes out of it. Get it done correctly and leveled.
Old Nov 6, 2015 | 10:16 AM
  #45
Mike
1 - Unfortunately, he is right... they will charge you for this because they "don't know anything about the car" yet.
2 - Did you check it while it was hot (and allowed to sit for 5 minutes)? or cold? I also had too much oil in mine... it burned off by the time I got back to them and it was close enough. If I were you, I would make them drain some. I should have when I went in.
Old Nov 16, 2015 | 02:55 PM
  #46
If anyone is following the story, it's been a couple thousand miles and the oil level is the same as when I picked it up. No loss.
Old Nov 16, 2015 | 03:43 PM
  #47
ceb's Avatar
ceb
Good. That means you don't have an issue.
Old Nov 16, 2015 | 03:48 PM
  #48
Seems like the TSB has resolved the issue. She purrs like a kitten.
I also had them replace the VTC actuator.
Old Nov 20, 2015 | 01:17 AM
  #49
icymichael's Avatar
tsxmichael
my car is in the dealer fixing this problem, i drive my car 880miles and my car was low 1.5 quart so they say yea they gonna fix! before that when i go to do the test i have to pay the oil change but if the car have the problem they gonna return the money when they finish! i will post here any information for now they told me its gonna be for long to fix cause the pistons its in back order and they have to replace the engine block too in my car i don't remember the reason! sorry for my english
Old Nov 20, 2015 | 09:54 AM
  #50
Haven't heard anything about replacing the block... I think the TSB might call for it only if the cylinder walls are damaged.
Old Nov 20, 2015 | 08:45 PM
  #51
icymichael's Avatar
tsxmichael
In some case like mine the cylinder get some damage cause that problem! So they have to change just in some case!
Old Dec 2, 2015 | 04:23 PM
  #52
d0nno's Avatar
Just completed the oil consumption test at Stevens Creek Acura in Santa Clara, CA and they confirmed that I was burning more than a quart of oil per 1000 miles. They went ahead and ordered the parts and I am waiting for a call from them in the next month or so. The service technician told me that when they get the parts in, I can drop the car off and they will give me a loaner vehicle for a few days or for however long it takes to fix.
They didn't charge me a dime for the oil consumption test and even washed it for me when it was done!
mada51589
Jan 9, 2025 04:40 PM
Mr.Tea
1/2G MDX (2001-2013)
26
Oct 9, 2015 04:27 PM
IIDXholic
Oct 8, 2015 07:53 AM
Allen_442
Sep 8, 2015 06:01 PM
