p0843
Old Aug 16, 2014 | 02:42 PM
Undisputed's Avatar
p0843
Wifes 2g tsx displayed the Code saying the transmission might not be working properly.2 weeks before the maintenance minder came on saying transmission oil should be changed.I did some research and found it could be 2nd or 3rd gear pressure switch,anyone have any idea how accessible these switches are on the transmission? Thanks
Old Aug 16, 2014 | 03:41 PM
UTAH TSX's Avatar
Easy to change it is a sending unit, 843 is for 2nd pressure switch just replace it (of it is unplugged it will throw this code also)
Old Aug 16, 2014 | 04:19 PM
Undisputed's Avatar
Just called the parts dept they told me they have two parts(switches?) one that goes on the top of the transmission and one that goes in the front, she wasnt able to tell me which one was the one i needed. Thanks for the reply btw
Old Aug 16, 2014 | 04:25 PM
Undisputed's Avatar
This is the part they have in stock , is this the one i need?
http://www.acurapartswarehouse.com/o...0-R90-003.html
Old Aug 17, 2014 | 04:30 PM
UTAH TSX's Avatar
I think it is the one on top the front one is usually the 3rd gear switch
Old Aug 19, 2014 | 03:26 PM
Undisputed's Avatar
http://postimg.org/image/sk47tp18t/
That was the switch that had to be replaced.Bought the part and swapped it out no more blinking d no more rough shifts.I also swapped out the front pressure switch while I was at it all I need to do now is a drain and fill. Thanks Utah tsx for pointing me in the right direction.
Old May 15, 2018 | 01:41 PM
jhonatantsx's Avatar
Hello guys,
was this the 2nd or 3 rd gear switch ? i need to replace my third one but I'm unsure as of whats the part number for it !!
vietxquangstah
Jul 23, 2019 05:16 PM
bolossa
Aug 17, 2014 12:05 PM
First Timer 09 TL
4G TL Problems & Fixes
Apr 7, 2011 03:57 PM
michmwong
Mar 28, 2011 04:46 PM
