Outer handle rod
Outer handle rod
New here so bear with me.
I am trying to replace my lock actuator on my 2010 TSX. I have the door panel off but cannot figure out how to get to outer handle rod connection to pull the old actuator out. Does the metal panel come off that would expose the inner door cavity? Trying to save a few bucks since the dealer wanted $300 to fix it.
I use this manual when working on my tsx. It's for the 08-10 Honda Accord but it's mostly the same. It has detailed instructions on removing and reassembling door components. Specifically in the body section starting on Page 1543.
Use the links below to download. They are protected pdf documents, but they are searchable and can be printed.
http://www.mediafire.com/download/7j...+Accord+SM.pdf
There is also a V6 version which builds on the previous pdf file.
http://www.mediafire.com/download/2x...-6+SM+Supp.pdf
I guess I should also say use this at your own risk because not all items are identical on our tsx...but most are.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jul 16, 2017 07:33 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
