Odd RPM Needle Movement
Hi all,
I've recently noticed that at times the RPM needle would kind of get "stuck" in a sense. Meaning I would be accelerating, and the RPM needle would stay stagnant. Then all of a sudden it will jump up to a certain RPM, instead of the normal steady progression upwards of the RPM needle. This doesn't happen all the time..most of the time the needle moves normally, at a steady pace up or down.
Anyone have any ideas? Or is that normal.
Thanks all!
Thanks all!
hey pyro not exactly sure..I'll try to get a video of it. It could be dirty..but I've only owned the car for three months. Bought it brand new 2012. Another explanation of what it looks like is that the RPM needle is trying to catch up after it gets stuck. Kind of like how a second hand ticks on one of those old school clocks. Does your car do that pyro?
Here is a video, not the actual issue but close...it's hard to get the actual issue on video while driving and on top of that it happens on sporadic accel. This video is an accel video and you can see how the needle drop is unnatural..at least not similar to any car I own. The drop is so rapid. I will try and get an actual video of the issue.
http://www.youtube.com/watch?v=2DDEE...ature=youtu.be
looks like the car is up and downshifting, it is an auto... i can take a vid of mine tomorrow. as the car shifts up, the rpm's drop.
check if you notice a pattern, do you by chance let go of the gas a lil bit before it jumps? i've used that trick to get my car to shift early. in heavy accel, it'll keep the lower gear for more power, then switch to the next gear for economy
Check out around 24 seconds..right when it upshifts to 4th gear I believe..and that rapid, unsmooth drop of RPM needle. It could be normal..but all the cars I've driven in the past it's never done that. Thanks everyone.
and I know I'm being extremely anal, but does your RPM needle once in a while bounce up and down slightly (at most 1 rpm) when idle Pyro? Whether it be in Park/Drive during idle. Just want to make sure everything is working properly. Got a long road trip coming up! Thanks!
justnspace (06-27-2012)
DerrickW
11-15-2015 05:52 PM
