OBD2 Scanner What to buy ?
Old Jun 19, 2013 | 03:57 PM
Old Jun 19, 2013 | 04:27 PM
UTAH TSX's Avatar
I would go with the 3rd or 4th one they say that they have datastream so you can see what the sensors are reading, missfire counts, emission readyness, etc. weather they will or not on our cars ???? just have to try I have a cheap one from matco tools it was $80 and it does not read data stream on any hondas but it will on several domestic cars I have tried.
Old Jun 19, 2013 | 05:33 PM
ojasdatt's Avatar
2009 TSX
But OBD2 scanners will work with tsx 09 right? I am just conforming as i cannot return it once i have bought it.
Old Jun 19, 2013 | 05:51 PM
swoosh's Avatar
takin care of Business in
Check my sig for discounts on OBDII device.
I got the ELM2 BT adapter and paired it with Torque Pro on Android, works like a charm on my TL
Old Jun 19, 2013 | 10:54 PM
waaasobe's Avatar
look at the scanner from mac its called the et99 great tool.
Old Jun 19, 2013 | 11:14 PM
2snail's Avatar
I think more newer late model cars are using can bus or obd2 if you can find a scanner that can change between reading modes you should be good. In fact I bought mine off amazon and it worked on my evox and it was can bus. I havent tried it on the tsx yet but I can try tomorrow
Old Jun 20, 2013 | 08:35 AM
ojasdatt's Avatar
2009 TSX
Amazon.com: Autel MaxiScan MS300 CAN Diagnostic Scan Tool for OBDII Vehicles: Automotive Amazon.com: Autel MaxiScan MS300 CAN Diagnostic Scan Tool for OBDII Vehicles: Automotive
Do you think this is compatible with tsx ?
Old Jun 20, 2013 | 12:44 PM
swoosh's Avatar
WOW....why do you need that?
just get the obdii bluetooth adapter ($15-ish) and get the app Torque pro ($5) and you will be able to scan the CEL and clear them
Old Jun 20, 2013 | 12:50 PM
ojasdatt's Avatar
2009 TSX
I have an iphone no anorid , so cant get the torque app. Can I use the Bluetooth with my laptop instead ?
Old Jun 20, 2013 | 12:56 PM
swoosh's Avatar
yes you certainly can....
also check this:
Rev - http://www.devtoaster.com/products/rev/
Engine Link - https://itunes.apple.com/us/app/engi...591557194?mt=8
Dash Command - https://itunes.apple.com/us/app/dash...321293183?mt=8
other apps:
http://www.popularmechanics.com/cars...iver-2#slide-2
Old Jun 20, 2013 | 01:37 PM
ojasdatt's Avatar
2009 TSX
Thx but buying anything from iTunes is very expensive
Old Jun 20, 2013 | 01:50 PM
Old Jun 20, 2013 | 01:51 PM
swoosh's Avatar
^^^ That is precisely why I went android...
do look for apps...you might get something for 4-5 bucks
Old Jun 20, 2013 | 02:02 PM
ojasdatt's Avatar
2009 TSX
Which one would you recommend to buy ?
"><img src=" /> ">
BAFX  Products (TM) - PIC18F2480 Bluetooth OBD2 scan tool - For check engine  light and other diagnostics - Android compatible : Amazon.com :  Automotive BAFX Products (TM) - PIC18F2480 Bluetooth OBD2 scan tool - For check engine light and other diagnostics - Android compatible : Amazon.com : Automotive
or
"><img src=" /> ">
Amazon.com: Soliport ELM 327 Bluetooth OBDII OBD2 Diagnostic Scanner: Automotive Amazon.com: Soliport ELM 327 Bluetooth OBDII OBD2 Diagnostic Scanner: Automotive
Old Jun 20, 2013 | 02:18 PM
swoosh's Avatar
the cheaper one is the one I have...I have it since a year without an issue
Old Jun 20, 2013 | 02:46 PM
ojasdatt's Avatar
2009 TSX
Thx a ton on all the info :-)
Old Jun 20, 2013 | 02:47 PM
swoosh's Avatar
Happy to help
Old Jun 21, 2013 | 12:06 PM
speedracer_2020's Avatar
Torque is also available for BlackBerry 10.
Old Jun 21, 2013 | 12:10 PM
ojasdatt's Avatar
2009 TSX
Darn it !!
I got switch to a Galaxy S4 soon
Old Jul 3, 2013 | 09:36 AM
drivedata's Avatar
Membered Register
bro did you ever buy one?
Old Jul 3, 2013 | 09:46 AM
ojasdatt's Avatar
2009 TSX
I bought this one cuz the I dont have an anorid phone
Old Mar 20, 2014 | 07:43 PM
808CU2's Avatar
Any OBD2 scan tool will work with your TSX pretty much anything 96 and up is OBD2. If you really don't work on cars to much then alot of higher model scan tool is not for you, if your looking to just see what sensor is triggering your CEL light then just get the basic scan tool, mind you alot of the scan tools out there give you brief what I would like to call generic codes that tell you what sensor is triggering the CEL light, and alot of times there's a domino effect with these sensors where one sensor is triggered by another sensor. Alot of times most of these sensors are emission problems. Hope this helps..!
Old Mar 21, 2014 | 10:25 AM
swoosh's Avatar
doesnt matter if you an an advanced user or not...the OBD tool with cheaper than any scanner...
plug the OBDii in ($15 on average) and just download a free app OR get torque pro for like 5 bucks...beats the hell out of any OBD2 scanner
Old Mar 21, 2014 | 10:28 AM
robpp's Avatar
Graphite Ghost
i have this dongle
Amazon Amazon
and the torque app........brilliant!
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
navtool.com
Sep 25, 2015 05:15 PM
