Need help with cv joint / tein ss install gone wrong
Old Aug 16, 2015 | 05:37 PM
kostantinos's Avatar
I was installing my tein ss today and one side went ok, the other side was being difficult.
I couldn't get the shock fork to go down
After a lot of forcing, I noticed grease coming out of the small side of the cv boot. I think the fork pushed the boot and it started leaking
I tried to pull the boot back into place but it doesn't move. I tried to move it with pliers too but nothing
Do I have to break the factory clamp and put more goop in it and reclamp it?
Old Aug 17, 2015 | 09:16 AM
TexasHonda's Avatar
If loss was small (perhaps a tablespoon or less), I would cut strap, reposition boot, and reclamp. I've used long plastic wire tire as temporary strap if time is an issue.
good luck
Old Aug 17, 2015 | 09:18 AM
maybe less than a teaspoon
is there a groove or something in there? as i can't figure out why I can't pull it back?
Old Aug 17, 2015 | 11:59 AM
Went out again to mess with it but it's too dam hot. I'm drenched in sweat
I couldn't break the clamp
Here's a pic
Old Aug 18, 2015 | 07:43 AM
ulrblitzer's Avatar
<p>Shove a flat head screw driver into the the downward point of that clamp, then twist it off or grab needle nose pliers if you're struggling with it. Find a video on inner tie rod replacement if you need a visual. That clamp has to come off when replacing the inner tie rod.</p><p>Word of caution, that clamp is a one time use item, so once you destroy it, have another one ready or use zip ties for temporary fix.</p>
Old Aug 18, 2015 | 08:09 AM
ok
ordered a clamp and grease from honda
i'm going to rip it off and use zip ties for now until i get the package
Old Oct 13, 2015 | 07:58 AM
Itr0059's Avatar
the strap tool is needed also , well it's super easy with it !
jblessing
Aug 8, 2018 09:43 PM
NitroViper
Mar 20, 2017 09:50 PM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
BoricuaTL
Apr 8, 2016 01:08 PM
nanos
Nov 12, 2015 08:41 PM
