Intermittent remote response
Hey guys, my 2010 V6 has developed an interesting issue. It responds to the remote for lock/unlock/trunk intermittently, sometimes taking a lot of button pushes to get it to work. Same issue happens with two old remotes and one brand new remote that I got under a TSB and never used, so it's not a remote problem. About a month ago I took the driver side door apart to replace the armrest, so I'm thinking there may be some connection loose on the door switch box, but the lock/unlock/windows all work flawlessly from the inside, plus the issue developed weeks after I did the repair. It doesn't respond in any way, no light flashes, no beeps or lock attempts, until it intermittently works. All the doors lock and unlock without fail, so it's not an actuator issue. Any ideas? Research leads me to an MICU problem as well, but I'm thinking it can't be that since it works from the inside. It's as if it is not receiving the signal from the keyless radio at all.
For posterity/informational purposes:
the immobilizer unit was the cause. In this generation, the immobilizer and keyless are one unit, on the steering column. It costs 70$ and needs to be flashed by an HDS at the dealer. That cost me 80$. No more intermittent remote response, works every time.
The following 2 users liked this post by DocRadar:
t3hhcaptain (08-08-2016),
TSXV6Guy (08-05-2016)
t3hhcaptain (08-26-2016)
syn11
02-24-2016 01:00 AM
tk2k6
02-14-2016 08:04 AM
TL_Trooper
01-10-2016 12:25 AM
