HID turn to yellowish light
My one of HID headlight suddenly turn to yellowish light. It starts with white light when I turn on the headlight and it turn from white to yellowish light within a 30 sec. Dose anybody know is HID included in our 4 years warranty? Thanks.
I am not 100% but it should be. Just take it to the dealership
khoacu2 (10-18-2012)
its worth a try going to the dealer though.. that doesn't sound normal for OEM HID .. you sure nobody changed the bulb to a 3000k one?
if you didn't mess with anything hit up the dealer
if you didn't mess with anything, go to the dealer, if they give you "sorry its wear and tear", explain that you haven't pissed in the housing. bulbs do not go yellow when they fail, they just don't produce this thing we call light anymore
tsxuser (10-17-2012)
My symptom was HID start with normal white light, then it turns to yellow, then it went out, but when you turn headlight back on, it start with normal white - yellow- then it went out again. I strong feel this is considered premature and defective item. It should went out right the way when you turn on the headlight if it comes to end of life.
I did call dealer before I make an appointment. Yes. they told me it is wear and tear item, they did not cover it. They said they charge $250 for the bulb and $60 for the labor. Of course, I am not buy it. I have an appointment with dealer on Sat. Will keep you guys posted.
AZ Community Team
Update!
My car has 37000 miles on it. Dealer ends up replacing my HID under warranty with no question ask. I was happy about this.Thanks for everyone's comments.
2010 TSX
I just ordered 5000K Morimoto bulbs from http://www.theretrofitsource.com/index.php?cPath=27
I had these in another car....beautiful white not blue or yellow lite.
Everyday I'm rofling
That is one powerful link there, ceb.
Any radical color change (yellow or purple) is usually an indication of an impending failure. HID bulbs (like any other bulb) will slowly change color with age, but if one bulb is visibly different from the other then it is getting to die.
rockyboy
12-06-2022 02:29 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
