Fuel Tank Pressure Sensor
Old Mar 12, 2015 | 09:58 PM
t3hhcaptain's Avatar
Angry Fuel Tank Pressure Sensor
Anyone know where this newfangled dohickey is on these cars?
I intermittently get a p1454 CEL. Was looking around on acurapartswarehouse.com trying to find a reference to a "fuel tank pressure sensor" but couldn't.
Light will be on for maybe a day, go out for a day, maybe come on again then rinse, repeat.
I replaced the gas cap because I saw there was an old part number, so I got the new part number. Didn't seem to work. Haven't been filling my tank past the automatic shut off (since another thread suggested this could be the problem... It's not.)
Maybe it's loose?
Anyone else have any experience with this?
Old Mar 13, 2015 | 12:46 PM
robpp's Avatar
Graphite Ghost
its something with the evap cannister. either valve sticking or sensor bad or a leaky hose maybe.
using oemacura parts .com this is how I found it
2012 Acura TSX 5-DOOR ELECTRICAL / EXHAUST / HEATER / FUEL CANISTER
Old Mar 22, 2015 | 05:54 PM
Sorry, I forgot to check back here...
It only happens every once in a while... Sometimes it will be off for days, come on for several hours, be off when I come out in the morning to start the car...
Still think it's the valve?
Old Apr 3, 2015 | 12:05 PM
If anyone is curious as to what happened here:
I read somewhere that this can be caused by overfilling the gas tank. So I've been testing over the past couple weeks...
I have only filled until the pump kicks off. I don't top it off. I haven't had the problem when I do this. I topped it off a couple fill ups ago and the code came back on. I haven't topped off anymore and the code stays off.
If you're having this problem and you usually top off, don't. Try that before buying a new sensor. You may have to not top off a couple times since your valve could be sticking as robpp says. Again though, I have discontinued topping off and the code does not come on.
Old Apr 3, 2015 | 12:20 PM
cu2wagon's Avatar
Thanks for following up! That's a helpful data point to have.
Old Apr 6, 2015 | 06:07 AM
Ayyyy! No problem!
Old Jun 19, 2015 | 09:17 AM
Another update on the situation... There were a couple more times that I had the code come back for a day, one of which was after having just filled up and aggressively accelerating getting back on a stretch of highway in nowhere land.
I used some seafoam in the crankcase and gas tank a few months ago and I have not had the code sense.
There were a few times at first, as I previously said where you may need to give it some time to work after not topping off, that it came on when the tank would get low. It eventually was coming on when the gauge was at the spot I'd usually fill up (about half tank).
So far so good and I haven't replaced the sensor, just not overfilling and I did seafoam once.
Old Jun 22, 2015 | 07:36 AM
TexasHonda's Avatar
I had this code come up on my 03 Acura MDX. After checking, the sensor was indicated and replacement fixed the problem.
Sensor is behind fuel tank near axle.
DTC is an FTP electrical circuit fault, so cleaning, etc is unlikely to have any effect.
good luck
Old Jun 22, 2015 | 09:43 AM
I'm not convinced the cleaning fixed the problem, just reporting that I did use seafoam in the tank.
Not overfilling has remedied my issue. It might be helpful for some other owners to try this before replacing.
good luck
Old Nov 25, 2015 | 08:42 AM
Another update: The problem is now happening when I go through the carwash during cold weather. It seems like if the water gets on the sensor it is making it throw a code.
I suspect the only option at this point would be to replace the sensor and then see if the wires, or something, need protected from moisture.
Old Nov 25, 2015 | 08:43 AM
good luck
Can the sensor just be removed or does the tank need to be emptied?
Edit - Also, is this the correct part? SENSOR, VENT PRESSURE for 2009 Acura TSX SEDAN|37940-SNA-A01
Old Nov 26, 2015 | 09:06 AM
TexasHonda's Avatar
Fuel Pressure Sensor is located behind the gas tank approx. near car centerline. You will need jack stands or ramps to elevate for access.
Suggest a TSX shop manual to help.
That is correct part no.
good luck
Old Dec 1, 2015 | 11:20 PM
RTM's Avatar
RTM
Have you checked the wiring leading to the sensor? Maybe it is corroded, and the water makes it go berserk?
Old Dec 3, 2015 | 12:31 PM
No, I haven't. I will do that when I get a chance.
Old Mar 27, 2024 | 09:58 AM
Azul Gato's Avatar
7th Gear
good luck
Do you know where the FTP sensor is located for a 2003 Acura CL type S? I am having this code pop up P04156 but my check engine light is not on. I changed the purge valve and the evap canister filter and the still is not fixed.
Old Mar 27, 2024 | 10:01 AM
Azul Gato's Avatar
7th Gear
Do you know where the FTP is location on a 2003 Acura CL Type S? I keep getting this code P04156 and it will not go away. I changed out the EVAP canister and purge valve and is still not fixed.
Mike Pilipenko
Mar 26, 2024 09:21 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
RobbDizzle
Oct 15, 2015 11:16 AM
joflewbyu2
Oct 8, 2015 11:16 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
