emergency break failure
Old Nov 8, 2008 | 03:22 PM
HannahHex311's Avatar
4th Gear
I have a 2009 6-speed tsx and couple weeks ago my car was parked at work and rolled into the tire of a thing called a boom lift. The emergency break was fully on. I went to the acura dealer and they said everything was normal. We checked the emergency break in a few tsx's at the dealer and noticed that they were all pulled very tight and when the break is released it jiggles when you touch it. I was just wondering if anyone else noticed this about their car or if mine was just a freak accident.
Old Nov 9, 2008 | 08:27 AM
HeavyDuty's Avatar
WTH happened to my garage
When I park, I always apply the brake first, then after the engine is shut off I return the stick to any gear before I get out.
So, the only way I'd know if the brake was loose would be if when I returned, took it out of gear, and started the car and it started rolling with the handle still pulled up. I'd recommend doing the same thing, it's like a backup for the brake, it won't roll (unless you park on a hill in San Francisco) if it's in gear.
"I drive a lot of rental cars, and they all have emergency brakes. Since the cars are all different, I never know where the E-brake is. They shouldn't call it an emergency brake...they should call it a make-your-car-smell-funny-lever." - - -Mitch Hedberg
Old Nov 9, 2008 | 10:36 AM
4th Gear
Yeah, I try to do that...but sometimes I don't. Its just unfortunate. Whenever I try to get acura to deal with me, they call it a "parking assist break" and I understand, But I wasn't even on a hill and I paid a lot of money for the car (well, I think it was a lot) and I expect the break to hold at least on flat surface. its kinda made my liking for acura go down the drain...thanks for you advice. I will definitely try to keep it in gear all the time!
Old Nov 9, 2008 | 01:02 PM
ShadowTuner's Avatar
Best-Comedian-EVER! Sucks he OD'd and died a few years back.
And to the OP, ya best to just leave it in gear to be on the safe side. It sucks royally that Acura won't work with you though. You'd think they'd want to bend over backwards for clients with the economy the way it is these days especially since they make most of their money in the service departments.
Old Nov 11, 2008 | 08:36 AM
HeavyDuty's Avatar
Yeah, Shadow, I know, it does suck. I was living in Orlando through 05 and had a chance to see him, but forgot about it. In true Tupac fashion, I heard Mitch does have a new CD out, but have yet to go looking for it.
Also HannaHex, pull up the lever a little harder. If you were to see how it's constructed, it's evident you probably couldn't break it if you tried, it's a very stout piece. Plus, the more you use it, the more it adjusts the rear brakes which helps by keeping the rear assist in tune lessening the share of work the fronts have to do. That will decrease the wear on the fronts, stalling rotor warpage and pad replacement.
$.02
Old Nov 11, 2008 | 01:35 PM
H22A_CD5's Avatar
Now when you said the dealer checked it and they said it was fine... what exactly did they do?
Old Nov 12, 2008 | 06:55 PM
4th Gear
they, I guess, inspected it, and then drove it and pulled it while they were driving. I was kinda being a stupid girl, because I was so angry with my car and with them. I should have made them test it in front of me, but, of course I didn't, and now it is their word against mine. I know a decent amount about cars, but not much about the emergency break...
Old Nov 12, 2008 | 08:03 PM
feuss2's Avatar
10001110101
It's uncommon for people to be able to properly use equipment they can't spell....
Trying bringing the car up to 10-15mph, shifting to neutral and pulling on the parking brake lever (in a parking lot where you're not in danger of hitting anyone or anything is best). This should slow down the car noticeably. It will not slow the car as quickly as depressing the brake pedal, but should still show some stopping capabilities. If this has little or no effect on the car's speed (beyond how it would normally slow down in neutral) this is a good basis for proving a defect. The brake that can be actuated from the center console is really there to stop the car from rolling when it's in park, and there have been many attempts to avoid calling it anything like emergency brake...
Old Nov 12, 2008 | 11:10 PM
4th Gear
Well, thanks for the advice. I guess. I will try that before I take it in again. However, maybe in the future it won't be necessary to put the rude comment before the suggestion. I understand that I screwed up and put the wrong BRAKE, but didn't realize I was turning in an english paper that needed to be perfect. I will make a rough draft next time. And I will definitely spell check.
Old Nov 13, 2008 | 08:47 PM
CGTSX2004's Avatar
Hannah, relax. He was just joking around. Note the smiley.
Old Nov 14, 2008 | 12:04 PM
Pay no attention to feuss2, he is an overall 2gen hater so he has to put something negative in before he posts.
Old Nov 17, 2008 | 09:54 AM
davidspalding's Avatar
Make a hole, coming thru!
In my old Jeep's old manual, it mentioned ALWAYS leaving the car in gear when parked, as the drum brakes weren't enough to "hold" the car on an incline. Also, consider that brakes heat up during use, and when you park, they will cool down. I presume that the metal will contract an eensy bit, resulting it not being as strong a grip as you had when you parked.
I also don't let the ratchet "click" while applying. I depress the button, pull the lever up until I feel a good snug grip, release the button,and let the handle down on the very next stop.
I've heard people suggest leaving your parking brake on snug, but not "tight" so as not to damage the disc/pads. Dunno about that....
Say howdy to Sonoma for me. I used to live/visit my family's cabin west of "Don't call it Gernie-ville" Guerneville.
Old Nov 20, 2008 | 07:32 PM
vistecr's Avatar
I had the same problem but with my 08 civic Si and one of the big guys from Honda came down inspected my car and one of the clips that holds the ebrake in place was faulty. they replace the hole rear brake assy and didnt have any more issues with it...
I havent seen anything with the tsx at the dealership but would deff update if i get some info on it.
Old Dec 28, 2013 | 10:38 AM
briq456's Avatar
Nothing like bringing a dead post back, but the parking brake on my 2010 is abysmal. My driveway has a slight incline and when i park and get out it's almost always possible to push the car forward. It's the weakest parking brake ever. Even when you pull it tight i would never park on a real hill and hope that the parking brake does it's job, because it won't.
Old Dec 28, 2013 | 11:12 AM
since the automatic cars dont really need the parking brake, I bet the parking brake is just not adjusted correctly, or not bedded in.
i know this is going to sound blasphemous, but try driving with the parking brake on for a few feet!
this will help "bed" in the pad.
additionally, you can tear out the center console and adjust the parking brake to catch sooner.
Old Dec 28, 2013 | 11:40 AM
briq456's Avatar
It's adjusted per the book. Raise the rear of the car, release the brake. Then unloosen the adjusting nut (check). making sure that the metal lever engages at the brake. (check) then pull the lever up one click (check) adjust until there is slight drag on the rotors (check) release brake and check there is no drag (check) parked the car in the driveway, pulled it up about 7 clicks (starts to get stiff after about 3 clicks) and it will roll down the driveway if I use my knee against the rear bumper. That's not right, and as far as bedding in the rear brakes, they were replaced over 10,000 miles ago. How much more bedding do they need? It's just an incredibly weak system to hold a car, and I have a six speed so I have no "Park" to put the car in and I think that the brake should be able to hold the car. Why it doesn't, I have no idea.
Old Dec 28, 2013 | 11:42 AM
briq456's Avatar
OH and anyone needing to adjust it you don't need to tear out anything, just lift up the rubber mat and towards the front under the USB and 12V outlet there is a little panel open it and you have access without removing so much as a single screw.
Old Dec 28, 2013 | 11:48 AM
you basically said, what i said...but longer and with more words. lol
Old Dec 28, 2013 | 12:11 PM
briq456's Avatar
Saying Tear out would lead anyone to believe that the whole console has to be removed and/or is a big deal. Tear down charges are for laborious items. Whereas removing a simple mat and opening a small trap door, not exactly tearing it out.
Old Dec 28, 2013 | 12:14 PM
BaoZZeR's Avatar
Oh sweet I didn't know you could adjust it. I always noticed that you had to pull the e-brake pretty high up to get my car to stop rolling
Old Dec 28, 2013 | 12:29 PM
robpp's Avatar
Graphite Ghost
if the brakes are adjusted correctly NEXT would be the cable. im sure it could stretch a bit over time.
Old Dec 30, 2013 | 05:46 AM
Cu2Suspect's Avatar
Moral of the story, always leave car in gear, my ebrake holds tight tho
Old Dec 30, 2013 | 08:05 AM
tomato tomahto.
same damn thing. except you're going in depth.
while any one with a decent brain could figure out what I meant by "tear out"
like you simply did.
Old Dec 30, 2013 | 09:39 PM
PyroDave's Avatar
tomato tomahto.
i thought you meant tear it up. directions unclear, got dick stuck in ceiling fan.
Old Dec 30, 2013 | 10:13 PM
briq456's Avatar
If someone who did not know the procedure, was interested in how to adjust it, telling them they have to tear something apart might have them picturing taking apart the whole console. Which, is not the case. So for anyone who was interested who apparently doesn't have half a brain and possibly thought "tearing it apart" might be more involved than removing a rubber mat and opening a door, well then sorry for clarifying and helping make it easier for those that only have half a brain. Cheers and happy new year.
Old Jan 9, 2014 | 06:10 AM
cris_crozz's Avatar
wow, i wonder how many 2010s have that issue... i'm just glad mine is ok. i can slide the gear to reverse, pull the parking brake, step outside the car and it won't move.
Old Jan 14, 2014 | 11:50 AM
bagwell's Avatar
2010 TSX
I adjusted my 10 - its very tight (no slack), but still doesn't hold the car well unless I really pull hard on the handle. I like my wife's electronic park brake...hit the button, done.
Old Jan 22, 2014 | 05:23 PM
DocRadar's Avatar
My 2010 is weak as hell. But it's a V6 so auto only. I fear jacking up the front with only the e-brake on though, it's such a piece that I absolutely need chocks anytime I do work. Also the previous comment about bedding it in- it seems as if you have a TL, from what I know from working on my friend's TL the parking brake is a drum inside the rotor. For us TSXers, it is a mechanism that activates the main rear pads. Bedding in has nothing to do with it. I think it's just weak.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
steve
Sep 30, 2015 09:23 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
kixo
Sep 25, 2015 03:07 PM
