Emergency brake cable adjust
Old Mar 28, 2013 | 08:13 AM
cbass78's Avatar
Talking Emergency brake cable adjust
I did a search for this and found nothing so i thought i would post this.
My 2012 TSX A spec ebrake had a lot of play and drove me nuts, so i started digging.
1. Open up your center console and remove the rubber mat at the bottom.
2. Take out the two screws and pry up with a small flat to pop out the power outets panel.
3. Disconnect the connectors
4. You will now see an adjuster nut , tighten it
5. celebrate success
Old Mar 28, 2013 | 11:03 PM
PyroDave's Avatar
not quite the proper procedure. take a look at my final post in this thread https://acurazine.com/forums/2g-tsx-problems-fixes-145/there-diy-adjusting-parking-brake-882503/
Old Mar 29, 2013 | 03:37 PM
iSeeYouTwo's Avatar
Pictures would help immensely!
Old Apr 1, 2013 | 07:08 AM
bagwell's Avatar
2010 TSX
Originally Posted by PyroDave
not quite the proper procedure. take a look at my final post in this thread https://acurazine.com/forums/showthread.php?t=882503
thanks, I missed this.
Old Jun 19, 2013 | 10:04 AM
kintox's Avatar
just wondering if any of you guys experienced the e-brake handle being a bit loose between you first lifting the handle up and the first click.. my dash brake light lights up when i lift the handle slightly up even before the first click. Is this normal?
Old Jun 19, 2013 | 10:07 AM
there is a sensor connected to the handle down underneath the center console.
tear into center console and see if that sensor needs adjustment.
it's a bolt with a nut on it, you adjust the length of the bolt to where it depresses.
kinda like a brake pedal switch
Old Jun 19, 2013 | 10:15 AM
kintox's Avatar
yeah i gotta check out the sensor, but is the handle suppose to be loose like that? i mean the brake works but I thought the handle was pretty stiff when I first bought the car
Old Mar 23, 2014 | 06:38 PM
frog_dude's Avatar
I opened the access hole in the center console. I am able to spin the nut but it just spins back to where it was. I know it’s on a cable and the nut might be stuck a little. Anyway to get this to turn?
Old Mar 23, 2014 | 07:34 PM
iCrap's Avatar
TSX AMG Type //M i-VVT
Yea i had the same issue. ^^
My ebrake is all loose and floppy and it drives me insane
lanechanger
Oct 13, 2015 10:56 AM
kixo
Sep 25, 2015 03:07 PM
TL14
Sep 24, 2015 04:37 PM
flybyglass
Sep 24, 2015 01:12 PM
