brightness
brightness
Just installed low beam hid bulb and drivet side is much brighter then passanger side. Its 6000k white and ill assume its the bulb
. Anything elae might cause this and should i wait till the night when it gets darker and see if it evens out?
Yes just replaced bulb didnt touch ballast. Now i have replaced bulb, it def will be harder but might able to swap them without taking bumper off.. But ill try to swap it and see if its def the bulb or not
Sun is gone and checked the light again and i see same brightness from passanger side too but only when i out my knee down and look from underneath lenz. Is it posible that lenz is off the place lil? We Did black out head light so took the lenzs out when we worked on light before.
WTH happened to my garage
Is it brighter or is the focal point at a different height? I guess two different manufacturers bulbs could have slightly different output. If you want the same, replace the 2nd bulb.
guitarplayer16
11-29-2015 02:03 PM
