Blinking Compass
Blinking Compass
Anyone experience their compass constantly blinking during a drive. It happens intermittently with when I start my car. This started 2 days ago and I tried calibrating it and that didn't help. Going to dealer tomorrow but curious if anyone else has been through this. I have a 2009 non tech package.
I think it means that it is calibrating. The compass also has an auto calibrating function, so maybe yours is mis-calibrated and attempts to re-calibrate automatically, hence blinking. Try to re-calibrate it again. Make sure you are away from large magnetic sources when calibrating.
I've recalibrated every time and I've even changed up the zones. Nothing seems to be working. Dealer will take a look at it but this is probably not going to be easy to diagnose. What a stupid problem.
LOL turn around! ah mah gawdz! on coming traffic!!!!!
I dunno I never looked at my compass I do however go into the diagnostic menu and watch the compass that shows you how many gps satellites you're using.. its a fun game I was down to 3 at one point and i go oh nooessss and bam 9 .. there are so many gps satellites up there.. its crazy
The dealer found the problem! The compass is mounted under the rear shelf and since I have aftermarket speakers and a sub so close to the compass, it has created a magnetic field that is disrupting it. Heads up to all you who have put in after market systems.
James, have you given any thoughts on putting some magnetic shielding material around the speakers in question. Check with your local Radio Shack or similar store for the material
Fascinating thread, thanks for updating with the info about the speakers, james_and7.
Didn't know those existing. Thanks for the tip. I will try it out. The blinking has definitely stopped since I took out those rear shelf after market speakers. It's been a few days now and everything is back to normal.
ripit
09-26-2015 06:19 PM
2010, acura, acurazine, blinking, calibrate, calibrating, calibration, compass, honda, mdx, n7000, nexen, recalibrate, tl, tsx
