Blackberry Bluetooth Phonebook Sync Issue
Loving my new TSX - first car with Bluetooth - sounds great.
However, every time i try to "import address book" I get an error message. It appears the names are showing up, and the numbers as well, but they are greyed out and unselectable. Only some numbers I can call. I've deleted the re-imported the phone book multile times....same result.
I work for a rather large company and have a few contacts. Might this be the reason why I'm having an issue? Anyone else?
bb8830 world edition, verizon. as i get more familiar with this website, i see it's a problem many have had - but the only fix i've seen seems to be on the lines of..."I tried it again and it worked!"
Hoping someone found something else cuz' I keep failing!
Doesn't look like your phone supports that feature. Here's a link from the Acura website showing which it features it does and doesn't support.
http://www.acura.com/models/handsfre..._index_new.asp
Go here and put in you phone/carrier and car info. Click on the available features, and you'll see that phonebook imports is not supported for your phone. I tried to copy that exact link, but Acura's website is being screwy. Sorry.
I had pretty much the same problem with my Sprint Instinct but when I noticed that the "NOTE" feature didn't work on my XM radio I finally took it to the dealer and it turns out there is a bad module on the radio that needs replaced...I just figured it was a problem with the phone but then when I had a problem with the XM Note feature I thought the two might be tied together....still waiting for the new module.
MilanoRedDashR
38
09-28-2019 09:13 AM
ivegotthenav
09-11-2015 07:51 PM
IndycarFaster
09-11-2015 02:52 PM
SUPRMN84
09-02-2015 11:50 PM
