Ac stopped working
Old Jun 20, 2016 | 07:26 PM
z643167z's Avatar
Ac stopped working
Now my ac blows lukewarm air. I replaced freon but that didn't fix it. What else can I check.
Old Jun 21, 2016 | 09:43 AM
hkycards's Avatar
While parked, turn your A/C on and pop the hood and look to see if your A/C clutch in engaging. If not, then that the issue. Next, check the A/C fuse (7.5 amp) and the A/C relays. If the fuse and relay are good, check to see if you have a R-134 leak.
Old Jun 21, 2016 | 10:00 AM
z643167z's Avatar
The a/c fuse will be underneath the steering wheel correct.
Mal so for the a/c relay.l I couldn't find which one it was. I opened the hood and removed the relay cover but didn't see anything noted for ac
Old Jun 22, 2016 | 08:19 AM
z643167z's Avatar
it wasnt the fuse or relay..im thinking it is the compressor is that a easy DIY? how much is the compressor?
Old Jun 23, 2016 | 11:27 AM
t3hhcaptain's Avatar
OEM Acura TSX SEDAN 2009 A/C COMPRESSOR parts
Search the forum for the term "manuel" and you will find a link to the service manual which explains that.
Old Jun 23, 2016 | 11:42 AM
damaged442's Avatar
When you replaced the refrigerant, did you have a gauge on it? Do you know for sure the refrigerant is still in the system, or may it have leaked out? You may have condenser issues also, so don't count that out. I am in the process of replacing my condenser, as it took a rock and the refrigerant leaked out.
Old Jun 27, 2016 | 10:43 AM
z643167z's Avatar
yes the gauge read maintenance required... so im not sure if it is the condenser or the compressor.. what is the difference
Old Jun 27, 2016 | 03:08 PM
Usually gauges read a certain amount of pressure. Does the A/C clutch engage at all? Kick on an off?
Old Jun 27, 2016 | 03:38 PM
z643167z's Avatar
No it does not.
Old Jun 28, 2016 | 09:42 AM
Does the gauge you are using have numbers on it indicating the pressure?
Old Jun 28, 2016 | 12:52 PM
RTM's Avatar
RTM
I think:
Compressor is the big expensive spinning thing mounted on the front of the engine.
Condensor is the expensive thing that looks like a radiator, mounted typically in front of your radiator.
I think the condensor might be a bit less expensive to replace, the only typical failure is it leaks.
If the compressor fails, it can send pieces of itself into the rest of the system, leading to some even more expensive cleaning and repairs.
Old Jun 28, 2016 | 01:31 PM
hkycards's Avatar
IF the A/C clutch is not engaging your A/C clutch may be our of specs. You can either replace the entire A/C compress or just replace the clutch. My A/C crapped out on my 2009 TSX with 157,000 miles on it. I just ordered a new A/C compress and receiver/drier. I hope to replace it within the next two weeks.
Old Jun 28, 2016 | 01:55 PM
It could be that - if OPs gauge has numbers on it rather than "maintenance required" it could have sprung a leak, if the pressure is super low. If the system doesn't have charge I don't believe the clutch will engage at all. If the system is overcharged it will engage and disengage rapidly, usually with some engine choking. Otherwise, if it still completely fails to kick on then I would assume some parts are in need of replacing.
dubz ASPEC
Jun 3, 2025 08:48 PM
RobbDizzle
Dec 1, 2017 01:32 PM
sidefx00
Integra
Feb 16, 2016 07:21 PM
dreem1er
Feb 14, 2016 02:41 PM
danperson1
Jan 26, 2016 03:33 PM
