2013 tsx won't start
Yes it does turn over and everything doors unlock fine so I don't think it's battery the starter clicks over like it wants to turn over but it's not I look at the fuel pump fuse n the little metal inside is not broken which means the fuse is not blown but the metal is a lil bent
Do you hear a lot of clicks when you try to turn it over?
If so, it is your battery and you need a jump. This happened to me numerous times with the OEM battery - All electronics would turn on but car would not turn over.
Yeah it does click but I have my remote control tapped off the fuel pump fuse to get ingnition power . I took off the traction control n I wasn't ripping gears but I drove it a lil hard and when I looked down at my control I seen it off so when I got home I push it back in and everything n it still won't start the fuse is still good
I know sometimes on my 09 i had started the car after it sat for 8 hours and backed it out of the garage and started it another hour later, it would just turn over and not start.
There was a software update they performed and it has been ok since.
cycdaniel
Dec 17, 2019 10:58 AM
