2013 TSX TPMS Control Unit
Old Aug 1, 2023 | 09:52 AM
Joker2023's Avatar
I have a 2013 TSX tpms problem. Changed all 4 tire sensors with new Autel MX sensors and programmed using Autel tpms tool. It worked for a few weeks but then got a System Function Error message and a code 45-01 Initiator Circuit Short. Went to junkyard and changed both front Initiators. I can reset the TPMS using Autel tpms tool and it works. All 4 sensors show the correct tire pressure. But when I turn the car off and back on, the TPMS light flashes and I get the same error message. I have to try replacing the TPMS Control Unit (Acura 39350-TL2-A12 Unit Assembly, Tpms) Number 3 in the pic. but I don't know where its located. Behind the dash somewhere. I don't have a good illustration of where its located. I need a service repair manual that shows it. I can't exactly pull the whole dash at the junkyard looking for it. I don't know how to test electrical parts yet. I can reset it but the error message comes back on as soon as I restart the car. The fuse # 29 for TPMS driver side is fine. Anyone have a link to the service manual ?
Where exactly is the TPMS Control Unit located, number 3 in the diagram ?
Old Mar 6, 2024 | 07:41 PM
Joker2023's Avatar
I solved my problem. I followed this repair guide by Honda (TPMS DTC Troubleshooting: 45) and tested using a multimeter. My control module was faulty, number 3 in the diagram I provided. I picked one up at a junk yard for around $20 and replaced it. Kinda hard to get to, high up in the dashboard. Cleared the tpms codes and tried Relearn by OBD multiples times (5) until all the IDs for the tpms sensors were written into the car using my Autel tpms tool.
Took a couple of screenshots of the troubleshooting pdf:
File Type: pdf
Old Mar 6, 2024 | 08:59 PM
Amazing update, thanks for the follow up
neuronbob
3G RLX Problems & Fixes
Oct 20, 2019 02:55 AM
Clean gen4 j35z6
4G TL Problems & Fixes
Jul 2, 2018 10:02 PM
ressling
Mar 13, 2016 06:08 PM
OnlyDaanish
Apr 22, 2015 02:23 PM
wmal13
1G RDX (2007-2012)
Jan 15, 2007 08:20 AM
